Thread: Peeling/Flaking slate tile around Pool
    Jan 2015
    Palm Desert, CA
    10
    Hi Everyone,
    I purchased a home in Palm Desert Last year and there was already a pool in place. I noticed that since I moved in the slate tile used around the pool above the water line occasionally flakes and peels off dropping a muddy flaky mess into the pool. Is there anything i can do, perhaps take a putty knife and peel it back even more then seal it?
    Blake
    Re: Peeling/Flaking slate tile around Pool
    Blake, that is exactly what I would do. I've got a few spots myself I have to tackle, and will be doing that when it warms up a bit. I have a salt water pool, and was warned this might happen. Good luck!
    Helen - Texas
    Helen
    Dallas Area, 16,000 gal IG, Easytouch 8 computer, Intelliflo 3HP Variable Speed pool pump, Pentair Smart Pump 4x160, Pentair 3/4 HP Booster Pump, FNS 60 DE 60, Mastertemp 400, Rainbow 320, Dual Timer w/ freeze protection, Intellichor SWG, TF100 Test Kit, POOL FILLED AUG 3, 2012, ORDER YOUR TF100 KIT FROM http://tftestkits.net
    http://www.troublefreepool.com/under...ie-t49936.html
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    You can use a pressure washer to blast it off. I have a few pieces of flagstone that do that and it's going to be an ongoing problem on mine from time to time. You may, or may not get down to a harder layer where it's less, but don't count on it.
    Essential Links:
    Feb 2015
    San Diego ca
    16
    It's going to keep flaking. Slate is horrible to use. Needs to be replaced or just deal with it
