Thread: NEC wiring requirements clarification needed
    Aug 2014
    Allen, TX
    67
    I have two questions about NEC requirements for pool wiring.
    1. My understanding is that I need two convenience outlets. Do these have to be waterproof and twist lock?
    2. Can I wire pump directly to a timer, or do I must have a twist lock plug to plug the pump in?
    Thanks, any clarification would be highly apprectiated, and suggestion where to get them, maybe a photo or two would also be helpful.
    10K gallons, IG vinyl free form Radiant Pool, 1HP SuperFlo 2 speed pump, 175 sqft Hayward C17502 plus cartridge filter, Intex Krystal Clear Saltwater System CS8110 Model 54601EG, Jandy Pro Series Underwater Nicheless LED. 1 skimmer, 1 suction outlet, 3 returns, The Pool Cleaner. Pool installation in progress as of 09/24/2014.
    Re: NEC wiring requirements clarification needed
    One convenience outlet is required, additional outlets are allowed, more than 10 feet from the water, some kind of weather protection, conventional not twist lock.
    Hard wiring the pump/timer is fine. If there is a pump outlet it must be twist-lock, but there doesn't need to be an outlet.
    Aug 2014
    Allen, TX
    67
    Thanks JasonLion. Would this work http://www.homedepot.com/p/GE-20-Amp...z1170vZ1z11epf
    Sure, that is fine.
