Thread: New, still brainstorming my build
    Feb 2015
    Orlando, FL
    4
    Had a half-sunk AGP for 2 years. 18'ish x 2' deep hole that I lined with a 3 course circle of blocks, sand bottom due to central FL terrain. Had a 16' round Intex that rusted out. Not a fan of the gap between the pool and the concrete wall, so am now considering building up another 3 courses and installing a vinyl liner. All DIY, trying to keep it on the cheap, but also more durable.
    Here's what I was thinking: 6 course block circle, then run this material around the interior, providing a smooth surface/protection from block abrasion as well as an overlap for the liner: http://www.amazon.com/gp/product/B00...A2RFSIF56F6W5J. Still the sand base
    I would build the block leaving openings for the skimmer and plumbing, but would have to cut through this material and the liner.
    Any thoughts on it? Any other ideas on using an overlap liner in a concrete block circle? Do I even NEED the poly material or is there enough of the liner to just lay it on the block and install my edging over it?
    TIA!
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Re: New, still brainstorming my build
    Have you considered typical wall foam. Seems it would be more wallet friendly and still provide protection of the liner from the concrete block.
    http://www.amazon.com/Gladon-100-Fee.../dp/B003TQMBLI
    Divin Dave,
    Feb 2015
    Orlando, FL
    4
    Thank you, Dave,
    I did consider that, but thought I might need something rigid to overlap the top edge of the vinyl? Or...am I overthinking it and the vinyl will simply lay on top of the concrete block?
