Page 1 of 2 12 LastLast
Results 1 to 20 of 24
Thread: Resealed my stone today, still looking good.
    skylar18's Avatar
    Apr 2013
    Austin, Texas
    299
    I was terrified when we built our pool as we used Oklahoma Flagstone for the coping and spa and fire pit, and decided to go with a Salt Water Chlorine Generator. Have been thrilled with that choice, hardly any maintenance. This was the sealer I put on before introduced to salt water a year and a half ago, and I reapplied today. I told everyone that I would keep everyone informed about the status of my natural stone and the salt water.
    I am happy to report that there has been no degradation of my stone yet. We are right at 17 months. Still probably to early to tell, but I am happy so far.
    43 x 19 Gunite Pool w/ spa and fire pit, 19,000 gallons, Pebble Sheen Aqua Blue finish, Jandy 2 HP VS E-pump, Jandy 580 sq ft Cartridge Filter, Jandy LXI 400k Heater, Jandy Aquapure 1400 SWCG, 4 Jandy LED color lights, Aqualink PDA and Iaqualink, Polaris 280 with Booster Pump. Polaris 9550 Robot Cleaner. 1 HP Silencer Air Blower for Spa http://www.troublefreepool.com/threa...NAL-INSPECTION
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Thanks for the update. Glad it's holding up well for you. Flagstone is my fav for coping.
    Jeff
    pragmatic's Avatar
    Jul 2011
    Friendswood, TX
    521
    Re: Resealed my stone today, still looking good.
    Yes, thank you for the update. DuPont makes a great product!
    ..oh, NICE Model you have there!
    Dave My Pool Build, ODK Build
    22X42 Gunite Freeform 23K Gal, 10X12 Spa
    Diamond-Brite midnight blue, 1800sq. ft Kool Deck
    Pentair Easy-Touch 8, 2-2hp Pentair, 500lb Sand Filter, 400K btu Pentair heater
    mitch08's Avatar
    Jun 2008
    Suffolk County, NY
    370
    Looks great. Can that be used on concrete pavers, and does it change the color of your stone or is it more of a dry / flat look?
    18x38 Inground Liner (25k gal) Paver surround, multi-speed pump, DE Filter, Raised spill over spa, TF-100
    Feb 2014
    Upstate, NY
    390
    Wow, it looks great. I was afraid to convert to a SWCG be cause of the staining issue. I just may reconsider and use the Dupont sealer you did.
    20X36 IG vinyl (18,000 gal), 3 sheer descents, Max-Flo 1.5hp VS 2300, Aquarite T15 SWG, C3030 filter, 250,000 BTU heater, Sharkvac XL (Hayward equip)
    skylar18's Avatar
    Apr 2013
    Austin, Texas
    299
    Quote Originally Posted by mitch08 View Post
    Doesn't change the color at all. If you don't wipe up the excess sealer that doesn't soak in it can leave a milky white looking film on the stone, but I am getting good at wiping it off. Took me only about an hour to seal it this time, not sure if I am missing spots or getting better at applying!
    Mar 2007
    San Rafael, CA USA
    12,082
    For concrete you can use Glaze 'N Seal multi-purpose sealer at around $55 per gallon compared to around $150 per gallon for the Dupont product (which might be better for stone). A good sealer that repels water will keep out the salt as well, though obviously splash-out and evaporation will leave salt on the surface. The key is to not have it soak into soft stone. Concrete doesn't usually have the same problems with salt splash-out. Sealing will help the concrete last longer regardless of the salt.
    Does the Dupont Stonetech or the Glaze-N-Seal make the stone slippery?
    Support the site
    skylar18's Avatar
    Apr 2013
    Austin, Texas
    299
    Quote Originally Posted by JamesW View Post
    The Stonetech does not make my stone slippery at all. The only way I notice it is on the stone is seeing water bead up when it hits the stone.
    Jun 2014
    The Woodlands, TX
    167
    That is the same sealant we have on our travertine and stone deco. I put it on about 8 months ago and it looks great. Glad to hear that you are experiencing similar results. I was not planning on re-sealng this year, I think we can probably go through another season based on how well water is still beading on the stone!
    8,000 gallon in-ground gunnite geometric. Wet Edge Satin Matrix. Triple overflow water feature.
    Hayward - TCell 15 SWG; TriStar VS Main Pump; SwimClear 425 Cartridge Filter; ProLogic 4 Automation, SuperII Water Feature Pump; Polaris 280 w/ Booster
    Link to my Build
    Apr 2014
    Texas
    11
    I also have Oklahoma flagstone coping and have been wanting to switch to swcg, but have been scared to because of the horror stories that i have heard. How do you apply the sealer, with brush or pump sprayer? Also do you worry about getting the sealer in the pool water while applying it. My wife will be extremely happy if i can prove a sealer will save our stone and i can install a swcg. Thanks!!
    21'6" x 38' Inground pool with Onyx pebble tec, Oklahoma flag stone coping with natural moss rock, Hayward DE6020 filter, Hayward Tristar SP3215X202 pump, Hayward Booster pump Model 6060, Ozone Joes OJ-45LR, Intermatic PE653RC. Pool completed in April 2014.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    In my case, I didnt use a sprayer because I was afraid any breeze that came along might cause overspray where I didnt want any to be.
    And I dont trust myself enough with a sprayer to apply it evenly enough all around anyhow.
    I used a 2 inch paintbrush and brushed the sealer on right around the edge of the pool so that none would drip in. I used a thick nap paint roller and did the rest of the deck. It worked out great for me without any problems.
    Quote Originally Posted by Bryantom View Post
    Divin Dave,
    Mar 2007
    San Rafael, CA USA
    12,082
    The Glaze-N-Seal on concrete, including troweled concrete, does not make it slippery after about a day or two of drying. It does have a little shine compared to being very dull looking with no protection, but it's not "shiny" nor slippery.
    Feb 2014
    Upstate, NY
    390
    I'm no expert here nor pretend to be but I would think that a product that's costs 100.00 more for the same amount has to be better?? (55 for a gallon as opposed to 150)
    Feb 2015
    Cypress, TX
    54
    Can you use this product for a moss rock waterfall? Or would that be too difficult?
    18k gallon IG gunite/pebblesheen with 3ton moss rock waterfall, 8 ft 12" raised wall & rock accents , 42sq ft 12" raised spa w/ 6 jets & cascading stacked stone waterfall, 3HP Intellifo VS pump,
    420sq ft Pentair cartridge filter, 400,000 BTU Pentair Gas Heater, 1.5HP Whisperflo water feature pump, 1.5HP Silencer Spa Blower, 3 intellibrite lights, EZTouch System 8
    skylar18's Avatar
    Apr 2013
    Austin, Texas
    299
    I used a roller for the top of the coping, fire pit and spa and used a paint brush for the up and down stones around the fire pit and spa and the edge and bottom of the coping. The first time I did it I was really anal and was in the pool with a towel making sure none of the sealer got in the pool. This time, since the water is now in the 50's and there would be a better chance of me flying to the moon than getting in the pool, I just was pretty careful. I did have some drip in the pool but still a very minimal amount. I felt it was less of a problem then when my daughter and 10 of her friends jump n the pool with lotion, makeup, perfume and whatever else they have on.
    The longer I have my pool I am finding myself how much more relaxed about what will get it out of wack and what won't.
    skylar18's Avatar
    Apr 2013
    Austin, Texas
    299
    QUOTE=ricky12;757926]Can you use this product for a moss rock waterfall? Or would that be too difficult?[/QUOTE]
    Don't see why not, just has to be dry to apply and has to stay dry for 72 hours I believe. Might have to reapply more often with the constant water going over the rocks.
    Mar 2007
    San Rafael, CA USA
    12,082
    Quote Originally Posted by Donny View Post
    Apples and oranges since the $150 product is for stone while the $50 one is for concrete (though they say it can be used for stone, it's not specifically designed to do so).
    Apr 2014
    Texas
    11
    I really love the color of my stone once it gets wet, anybody have a wet-look sealer that they have used with success for a salt water pool?
  20. Back To Top    #20
    Jul 2014
    Austin, TX
    78
    This is so helpful! Thanks for posting your updates!!
    Just getting started! Inground freeform gunite pool, 17x32, 3.5-5ft depth, SWCG, French Grey mini pebble Stonescapes, NPT Arctic Lagoon glass tile, raised wall with 3 sheers, Polaris robotic cleaner, Cartridge filter, 550 sqft concrete/Kool-dek; Dig to begin 10/2017!
