Results 1 to 16 of 16
Thread: Pump and fitting
    Aug 2014
    Texas
    30
    Pump and fitting
    Hi everyone Im Rafy I'm new in the forum and i live in Texas.
    I have a 14x36 ,Fiberglas in-ground pool ( 14,000 gal) that has 2" piping on the suction and return side. I bought a new pump (Hayward super pump) to replace the old one.
    This new pump came with 1 1/2 intake and output fittings. Can I adapt this pump to my suction and return pipe? Do I need to return this pump and get another one?*What will be the down rage On this?
    Advice will be appreciated..
    Hayward Super Pump series ( SP2610X15)
    Hayward Pro Series Top Mount High-Rate Sand Filter(S244T)
    Rainbow Lifegard Chlorine/Bromine Feeder
    Thank you...
    Rafy
    Re: Pump and fitting
    Welcome to TFP!
    Your pump will be just fine. You simply need to use an adapter to convert to 1 1/2" pipes close to the pump. The short sections of 1 1/2" pipe will have only a very tiny effect, so that overall the system will behave very nearly as if it was 2" pipe throughout.
    Aug 2014
    Texas
    30
    Thank you a lot I will start looking for those adapters to put back my pool a soon as possible.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    It's nice to have unions so the pump can be serviced but you likely need something like this to reduce the 2" pipe down to something that will screw into the pump. Just make sure they are the right threads.
    Solar Blanket, Well Water, Borax Added. 68
    Aug 2014
    Texas
    30
    Sorry it has taken me so long to respond..
    Thank you for your info.
    This is a picture of what I need to replace..I will use this part for this project...
    Am I going in the right direction?
    14 x 36 In-Ground Fiberglass Pool Free form 14000Gal
    Rainbow Lifegard Chlorine/Bromine Feeder ( not in used )
    Yep, definitely heading in the right direction.
    By the by, the threaded to slip adapter at the bottom of your picture is fine, but I prefer to use a section of threaded CPVC pipe instead. You buy a "CPVC Nipple" and cut it in half to get the section you need. CPVC is much more heat resistant. It is possible for the pump to overheat, and a short piece of CPVC will prevent that from causing problems with the plumbing melting. Overheating is quite rare, so this is hardly critical, just my preference.
    Aug 2014
    Texas
    30
    Great!!! I will work on this today. It is amazing that in just five emails I can get advice on how to do it, plus the suggestion on parts. I went to places that are expert on swimming pool and they make this almost impossible, more like suggest that I need to hire a pluming guy. I'm not expert in pluming, however I know I can do it with some guidance.
    Thanks all for yours advice, and suggestion. I will let you know how goes will.
    Rafy.
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Jason, Nice tip on the CPVC.
    Aug 2014
    Texas
    30
    Well the job is done, and look like is ok... Thank you everyone for your input and advise.
    I've being trying to upload pictures to all see the job done however no results were shown in uploading.
    Now, my sand filter shows 22.5 psi. Is this normal? I have a new pump, Hayward SuperPump, new pipes, and I backwashed the sand filter about a month ago. My question is, did i do something wrong? Would I have to fix something?
    P.s. All the pipes from the pool to the pump to the filter are 1 1/2 inch. I will try to upload pictures later.
    There is no normal for filter PSI. It is different for every pool. You are within the normal range, if perhaps towards the higher end of the that range.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,005
    Hi Rafy,
    this may help you in uploading pics.
    http://www.troublefreepool.com/threa...oto-s-Tutorial
    Divin Dave,
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,005
    Yup,
    we know..... they typically are no better at testing your pool water and getting the right chemicals in it either.
    There some good pool stores here and there, but few and far between.
    Quote Originally Posted by Rafy View Post
    Great!!! I went to places that are expert on swimming pool and they make this almost impossibe
    Rafy.
    Divin Dave,
    Aug 2014
    Texas
    30
    Thank you I will try it to load the photos Dave...
    Aug 2014
    Texas
    30
    Here is the photos to show what I did...I know for some of you guys is simple however for me is my first project. And always baby steps. Thank you all for your support and advise...
    Attachment 34400
    Attachment 34401
    The photos that show filter PSI
    Attachment 34402
    Ok that's all
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,005
    Hi Rafy,
    for some reasons, your links to the pics are invalid, and we can't see them.
    if you didnt use photobucket, it might be because you are over the allowable limit to post pics directly through the forum.
    just thought I would let you know.
    Attachment 34400
    Attachment 34401
    Attachment 34402
    Ok that's all
    Divin Dave,
    Aug 2014
    Texas
    30
    Sorry!!!
    I didn't know...
    I maybe do something wrong... I will back to the link that you send me and try one more time... Thank you for let me know...
