Page 1 of 2 12 LastLast
Results 1 to 20 of 21
Thread: Re plaster or repaint? Pool Poll
    mellenw's Avatar
    Jun 2011
    Dallas, TX
    24
    Re plaster or repaint? In ground 60's vintage concrete pool 15K gal. Several layers of epoxy paint over original surface Walls and floor have minor pits that trap dirt particles but sweeping every few days keeps them moving to the filter. Repaint myself will cost @$600 (epoxy paint is about $100/gal) Re plaster and regrout tile @$3,100. WHAT WOULD YOU DO?
    16 K gallon, IG, Concrete pool built approx 1970. (Resurfaced with plaster May 2015) 9 ' deep approx 17'x 33'. (1) skimmer, (1) bottom drain, (2) jets. PUMP: Hayward Max-Flo XL 2 speed 1 HP (installed May 2015). Sta-Rite T240BP-1 Crystal-Flo sand filter (installed 2007), Pentair 320 in-line chlorine /bromine feeder (2007 & 2012). TFPC with Borax/Bromine. taylor K2006 test kit. Mellen, Dallas TX
    Re: Re plaster or repaint? Pool Poll
    You should absolutely re-plaster. You will get a better surface that requires less maintenance and costs less in the long run. Paint never lasts very long and ends up being more expensive in the long run, not to mention the frequent issues such as what you are experiencing now.
    38,521
    Welcome to TFP!!!
    I would never paint a pool ... too much work just to have to redo it every couple years. Add it will not fix the surface irregularities.
    Have all the paint and plaster chipped out and put in plaster or a pebble product. By maintaining a balanced pol year round, you should be able to have the plaster/pebble last well over 10 years.
    mellenw's Avatar
    Jun 2011
    Dallas, TX
    24
    Thanks for the quick and decisive reply to go with plaster. Will do. Next question is color? Pool is white but considering a light blue or tan thinking that dirt and algae is less visible if I fall behind on maintenance. I also believe that algae stains when they inevitably occur will be more difficult to remove from a white surface. I tend to let the pool sit dormant November - March with a leaf catching net over it. In Spring, I drain and power-wash surfaces and refill. (it only costs about $20 to refill, even in TX). Pool is well shaded and drain is 9' deep. Heat is not really an issue with color selection. Pool water temperature rarely exceeds 80 degrees even in August but water is generally very chilly 70 degrees. Come to think of it. If I did choose a darker color pool might be more comfortable in the spring and fall. Perhaps the question of how pool color effects pool temperature and extends pool season should be in a new thread.
    mellenw's Avatar
    Jun 2011
    Dallas, TX
    24
    I think I have the answer to pool color and temperature. Key words Thermal Mass. The surrounding earth temperature will be the main determining factor in water temperature of an unheated in-ground pool. Not fond of dark colored pools unless there is a thermal benefit in my situation which does not appear to be the case. So back to white, light blue or light tan to better mask algae and dirt. Tan might be nice for a change and would go with terracotta coping as well as white or blue. Perhaps my theory that white cars require less cleaning because the dirt does not show up like on a dark car applies for pools too.
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,824
    Grays give a steel blue (not bright blue) water color. Ours is tinted plaster so fairly mottled and good at hiding dirt (or maybe I don't have any) but obviously not bugs and leaves.
    Tans give turquoise water. Whites give bright blues. Black gives seductive water color.
    Probably slight boost in full sun for darker colors. Mostly get what you like to look at.
    I'm sure others will comment on the algae thoughts. Properly maintained you will have no algae so no need to accommodate for that.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    MARCO...polo's Avatar
    Oct 2014
    East Contra Costa County CA
    102
    There are a bunch of YouTube vids and many online text docs that try to explain all the different factors that go into the colors achieved using the different plaster colors. When we chose our color (medium gray) we did our best to thoroughly confuse ourselves by reading it all. One of the things we did was to take a flight via Google Maps around the area peeking into other peoples backyards to see what they had and what we liked. Good luck.
    13,000 gal.Peanut shaped IG Plaster (med. gray) w/ 7' raised spa. ALL Pentair: Intelliflow 3hp VS, Cartridge filter, 400,000 btu heater, 2.0hp spa motor, Easy Touch control panel & is4 spa side switch, Intellichlor 40C SWG, Paramount PV3 In Floor cleaning system, spa spillway and two sheer descents. Solar: 10 FAFCO panels 1.5hp booster. Testt kits: K-2006 & K1766 (Chloride/Salt) Fill date August 15, 2114.
    mellenw's Avatar
    Jun 2011
    Dallas, TX
    24
    Thanks all. Off to the pool supply showroom to look around.
    Casey's Avatar
    SW PA
    10,457
    Chlorine takes care of algae and a solid cover prevents debris. If your investing in new plaster, closing the pool right and taking care of new plaster with balanced water is the only way to go. You will need to adding acid on a weekly basis for up to the first year of the refinish.
    mellenw's Avatar
    Jun 2011
    Dallas, TX
    24
    The deed is done, new plaster. Filled pool by am Saturday 5/2. Following new plaster start up advice. Brand new City of Dallas water has a green hue for some reason. Contractor said nothing about sequestrant.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Congratulations on the re-do! Post up a picture of that please.
    Essential Links:
    Mod Squad pooldv's Avatar
    DFW, TX
    24,513
    Yep, dallas water is green, it will clear up after a few days. No sequestrant required.
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    I'm excited to watch this....please post pics throughout the project.
    Inground 13,200 gal Vinyl, Pentair 3/4 hp pump, Pentair Sand Dollar filter, Polaris 280
    Pool School, Pool Math, CYA to FC ratio chart, Testing Kits
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,824
    Fresh water almost always looks a bit greenish from what I've seen here.
    Oct 2014
    Columbus, Ohio
    23
    Hopefully all of the paint and hollow base were removed prior to plastering, $3100 for all of that is a tremendous deal. As long as that was the case you will benefit from this choice for years.
    mellenw's Avatar
    Jun 2011
    Dallas, TX
    24
    It took two men 4 days to chip away the epoxy paint and clean out hollow spots (with water pressure and hatchets, yes, Boy Scout style hatchets) They lost money on that detail. As I suspected the tile and coping was bad too. Tile was replaced and coping pulled out and repaired. Total cost now $6,500. Water is now clear and balanced
    New questions
    1. I ran pool vac too soon and scuffed up steps with black marks from vac head. I realized error and bought a vinyl pool vac head but not sure how to remove the skid marks.
    2. Calcium hardness is a factor. I measure 120 and read that it should be double that number. Any advice. FC=5, PH=7.8, TA=80
    3. Hard to hold FC steady without stabilizer. When can I add CY?
    Mellen
    I would love to show pix but can't figure out the attachment. Will try again later
    38,521
    To post more pictures, you either need to raise your storage allotment by Becoming a TFP Supporter or follow the How To Post Pictures tutorial.
    not sure about the marks, I would think scrubbing should take it off.
    What does the installer say about the balance?
    I think you should be fine to add CYA anytime (sock in the skimmer)
    The CH may still rise from the plaster.
    mellenw's Avatar
    Jun 2011
    Dallas, TX
    24
    I'll study posting pix as suggested.
    New question about calcium hardness and new plaster. I tested for CH and have reading of 120. I entrered 120into pool calculator and it suggests adding 426 oz of calcium chloride. That's 26 pounds !!! Is this correct? Come to think of it, if I dumped 13+ boxes of 20 mule team borax when i did the borate thing years ago... 26 pounds of CL is proportional.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Quote Originally Posted by mellenw View Post
    What did you increase it too in Pool Math? You could increase it to the low 200s and you'll be at the bottom end of safe pretty soon. Calcium doesn't evaporate so it will build up. You may see a slight increase with the new finish as well. As Blizzle mentioned, you might want to follow the balance set forth by the installer to have warranty issues covered. Ask him for sure.
    Essential Links:
  20. Back To Top    #20
    mellenw's Avatar
    Jun 2011
    Dallas, TX
    24
    Jason, I paid the $30 lifetime support donation some time ago.
