Results 1 to 8 of 8
Thread: What's up with this Chlorine?
    Apr 2012
    Klein Tejas
    249
    This test is from my MIL's pool, not mine. Last summer she had to fire her pool service as the CYA had reached a level so high that the weekly shocking seemed to do nothing. I drained half the water and replaced. That got everything back to normal. My MIL has been keeping up with the maintenance since then. I come in behind her with testing and chemical additions.
    A couple months ago, my FIL got sick and died. The pool was neglected a little (December) while my BIL was staying with Mom.
    For the last two weeks the Chlorine test have looked like this. The Chlorine drop test does not turn pink with a scoop of regent.
    I turned off the puck feeder two weeks ago and removed the floater this week.
    Is this caused by the chlorine being insanely high or something else? Recommendations?
    Pool is DONE!
    Pentair Intelliflo VS3050
    Pentair Easy Touch 8 + actuators + swg
    Pentair IntelliPH
    Pentair 400btu HD heater
    3- Jandy WaterColor LED's
    Hayward C5030 525sqft cartridge filter
    Waterway spa blower
    Re: What's up with this Chlorine?
    The OTO chlorine test will turn orange when TC is between roughly 15 and 30, and will turn brown at 30 or higher.
    The FAS-DPD chlorine test can flash pink and go back to clear when you add R-0870 powder when the FC level is really really high. Usually adding a second scoop of R-0870 will turn it pink in this situation. Really extreme cases can require a third scoop.
    So it looks like the FC level is really really high. I suspect that the CYA level is also really high, or you would lose all of that FC rather quickly.
    jcowart's Avatar
    Jun 2012
    Labelle, TX
    320
    It kinda sounds like your cya is crazy high and you have no chlorine. Try a test with half tap or distilled water. You are using pucks so your adding to the cya. I have an 18000 gal pool and a 25lbs bucket will raise my cya by almost 100. You can see how it gets out of hand in a hurry.
    17500 gallon Doughboy AGP, Hayward DE filter, waiting for the 1.5hp DB pump to go out.
    Learn to take the advice here and be trouble free or use the pool store's advice. "You can't do both and get very far"
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Quote Originally Posted by bigdave160
    From what I can see in your pic, you are using the OTO (Orthotolidine) chlorine test which does not require a "scoop" of reagent - only the OTO drops. The OTO test is good for detecting the presence of chlorine in a pool. If chlorine is present, the sample will turn some color (a shade of yellow). The darker the yellow (or orange-brown in cases of extremely high chlorine) , the more chlorine is present. If it remains clear, there is no chlorine. This test measures primarily measures Total Chlorine (TC). You really need to know the Free Chlorine (FC) and Combined Chloramines (CC), so the OTO test is not recommended for ongoing chlorine maintenance as it simply is not precise enough. We recommend the FAS-DPD chlorine test which includes a powder and a liquid reagent.
    Hopefully, you will begin using bleach for chlorination as continued use of pucks will once again lead to unmanageably high CYA levels. Once the water hits around 70F or so, I would rely on the SWG for ongoing chlorination. During the off-season, occasional doses of liquid bleach should keep the chlorine in check. At this time of year, I'm adding chlorine about every other week or so to maintain a proper level.
    Apr 2012
    Klein Tejas
    249
    I might not have been clear. I did do the FAS-DPD but one scoop turn clear almost instantly. I'm going to change some water and not change the chlorination as the MIL is building a new home just down the block from us. She'll be selling this house.
    Pool is DONE!
    Pentair IntelliPH
    Waterway spa blower
    FlyAU98's Avatar
    Jul 2014
    Ft. Lauderdale, Florida
    59
    I'm not quite the expert here...yet....
    But it seems that you need to find out:
    1) what your CYA level is
    2) what your actual chlorine level is (try more scoops)
    3) a full set of test results would help
    Then report back...
    15.5K gal, concrete, 1HP AO Smith pump, Hayward C1200 cartridge filter, Zodiac T5 Duo auto cleaner, 8 panel solar heater controlled by Hayward Aqua Solar GL-235
    Try using 3 scoops of the R-0870 powder. What is the TA?
    Support the site
    Mar 2007
    San Rafael, CA USA
    12,082
    And use a 10 ml or 5 ml sample size to save on FAS-DPD drops. For a 10 ml sample size, every drop is 0.5 ppm; for a 5 ml sample size, every drop is 1 ppm.
