Thread: Intermatic timer - Can't turn off
    Question Intermatic timer - Can't turn off
    Hi All,
    I can't turn my pump off using the intermatic timer. It stays on just fine though! I've got the 2 timer type - 1 for the main pump power/time and another for the Polaris. The main switch flips on and off completely so I know it's not the wheel with the little metal clips/trippers.
    I've done a quick search and some reading and get the impression that this is more of a replacement part than a fix-it item. Anything else I should look at before ordering a new one? Will I replace the entire thing or just the one side/timer?
    Thanks!
    12000 Gallon Freeform Pool
    SWG
    Jandy AquaPure 1400
    Leslie's DPD Complete Chlorine Kit + FAS/DPD Chlorine Tester and Swirler from TFP.com
    Tree covered lot - cottonwoods and crepe myrtles. Great shade during the summer, miserable fall cleaning leaves from the pool.
    Re: Intermatic timer - Can't turn off
    One thing to check before replacing the mechanism, if you have the freeze protection option on your timer, it might be the freeze protection triggering, and the timer might be fine.
    Thanks for the suggestion, Jason. I do have a freeze protection device. It's set to 44, but it's 59 right now. Is there some way to test and see if that's causing the issue? Maybe just disconnect its wires?
    Here's a photo of what I have:
    SWG
    Jandy AquaPure 1400
    Try turning the freeze protection down to see if that works.
    Support the site
    Turning down the freeze protection seemed to do the trick!! Thanks!
    SWG
    Jandy AquaPure 1400
