Results 1 to 10 of 10
Thread: Ants in Automation Control
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    Whats the best way to keep them out they are the size of a needle point. Thanks
    13,000 Gal Pool & Spa
    Jandy Automation /w IAqualink
    Autopilot SWG
    Jandy 2.0 HP VSP, Filter Cartridge
    Taylor (FAS-DPD K-2600, Pool Surface: Plaster
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    A quick google search on how to get rid of ants will give you multiple ways if doing it.
    One way is to take some sideway kids chalk and draw a barrier around the automation panel. The ants won't cross it. They will be repelled by the calcium carbonate it's made from. Seems silly but it's supposed to work.
    Try to see if you can see where they are coming from and attack the colony there.
    Jeff
    Re: Ants in Automation Control
    They also won't cross a line of borax, which works rather better than chalk on level rough surfaces (though much worse on smooth vertical surfaces).
    mothballs work as well
    18' x 36' saltwater inground vinyl pool
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    They are entering through the little reset hole, I think I'll try the mothballs.. Thanks everyone
    Autopilot SWG
    jcowart's Avatar
    Jun 2012
    Labelle, TX
    320
    I see you live in Florida. If they are crazy raspberry ants, good luck. They will kill themselves to build a bridge to get into electrical equipment.
    17500 gallon Doughboy AGP, Hayward DE filter, waiting for the 1.5hp DB pump to go out.
    Learn to take the advice here and be trouble free or use the pool store's advice. "You can't do both and get very far"
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    Do you think mothballs in the control box would hurt the electronics from the fumes? The ants are now gone...
    Autopilot SWG
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    I wouldn't think the fumes would hurt the electronics.
    Jeff
    jcowart's Avatar
    Jun 2012
    Labelle, TX
    320
    Might try a product with Fipronil in it. A friend of mine has a license and sprayed it. It seems to have worked. You can find a lower concentration over the counter product under the name Taurus SC. I no longer have problems with any kind of ants.
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    Thanks again...
    Autopilot SWG
