Results 1 to 7 of 7
Thread: New Pool: DE Filter Pressure vs Backwash frequency
    ssml11's Avatar
    Jul 2014
    Miami/Florida
    131
    I have a Hayward DE 36 and my new 10k gallon pool was filled exactly one month ago. I haven't done any backwash yet because I was told to backwash only when the filter gauge displays a gain of 10 in pressure.
    The pressure gauge has read 3 since the pool was filled, and it has only gone up maybe a hairline in 30 days.
    I am currently running my ecostar pump at 1300 rpm for 16 hours a day. If I increase the pump's speed to 1800rpm the pressure goes up to 9, so I know the gauge is working.
    The question is, am I ok in not backwashing not even once since pool was filled? At this rate it will take months for gauge to display a gain of 10 in pressure.
    12' X 25' in-ground. Hayward EcoStar Pump, Hayward DE 3620 Filter, Hayward Pro-Logic PS4 with Aqua Connect for automation, Hayward ColorLogic Led lights, Silencer Blower, Four Jandy DeckJets, Salt Pool, Neverlube Valves with One Actuator. Built by owner.
    30,424
    Re: New Pool: DE Filter Pressure vs Backwash frequency
    Yes, you are ok (sort of). I assume your pool is clear and doesn't get much debris.
    A somewhat better way to test is to test at a higher rpm (enough to get to 10 psi). TFP suggests a backwash at 25% of the clean pressure, so if you now get 10 psi at maybe 1900 rpm, test it at 1900. Then when your psi increases to 12.5 or so (25%) it is time to backwash.
    Most pool gauges are pretty inaccurate especially at low, low pressure so the 10 psi will make it easier to judge your 25% increase.
    Sep 2013
    Dallas-Ft. Worth Metroplex, TX
    810
    I would use max speed to gauge filter pressure for cleaning purposes.
    14K Freeform Gunite w/60% Blue Quartz plaster, Quad DE filter, Intelliflo VS Pump + Booster for Cleaner, Aquacal Heat Pump
    ssml11's Avatar
    Jul 2014
    Miami/Florida
    131
    So you guys think I should pump filter speed up for a couple of weeks and see if it goes up?
    Backwashing after 25 percent into? Woao then what's the point of the 10 pressure increase deal?
    And yes, pool water is so clean it looks like zephyrhills water.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,031
    Quote Originally Posted by ssml11 View Post
    The 10 psi pressure increase is one of those pool store legends like "3 is the ideal chlorine level" without taking CYA into account.
    All you need to do is get a baseline reading at max RPM and then let the thing run at low speed normally. Maybe once a week, take it up to max again and see what the difference is. My DE filter can go months without showing any increase. Once it starts climbing, it tends to climb pretty fast after that.
    Feb 2015
    San Diego ca
    16
    I backwash open and clean my filters every four months. Then reset it with the correct amount of de
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Quote Originally Posted by Geelow View Post
    That's great if it works for you, but this can vary greatly from pool to pool.
    Essential Links:
