Results 1 to 8 of 8
Thread: What might have caused this?
    Jul 2013
    Mesa, AZ
    15
    Discharge pipe from pump disconnected(?) with such force to bend the pvc pipe.
    https://flic.kr/p/qMVhGt
    https://flic.kr/p/qMVgrc
    https://flic.kr/p/r5nQCv
    40k Pebble Pool with Spa Spillover
    (2) Hayward Pro-grid 6020 DE filters
    (2) Hayward pumps 1.5 hp, 1.60 sf, 2.4 thp
    Hayward H series
    TF-100 test kit
    Citizen's Avatar
    Oct 2014
    Orlando, FL
    92
    Re: What might have caused this?
    Quote Originally Posted by Nixid View Post
    Can you repost pics, they are not popping up for me
    My guess is that the flow was completely blocked somehow, and the water in the pump and connected pipe seriously overheated, weakening the PVC. With flow completely blocked, the pressure would be roughly 40 psi, and with the pipe weakened from the heat it could easily fail. That doesn't tell us where the blockage was however.
    pragmatic's Avatar
    Jul 2011
    Friendswood, TX
    521
    ^Agreed! Heat definitely involved!
    Dave My Pool Build, ODK Build
    22X42 Gunite Freeform 23K Gal, 10X12 Spa
    Diamond-Brite midnight blue, 1800sq. ft Kool Deck
    Pentair Easy-Touch 8, 2-2hp Pentair, 500lb Sand Filter, 400K btu Pentair heater
    Any chance freezing blocked the line and caused it to overheat like Jason said?
    18' x 36' saltwater inground vinyl pool
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,011
    Holy Cow!
    Yeah, that got hot!
    Divin Dave,
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    I had a similar thing and mine was caused by the failure of a check valve between the pump and filter. It was the flap type valve and the flap tore loose and got wedged so that it blocked the water flow. I don't see a check valve in your set up but, I agree something blocked the water flow causing the water to overheat. Block that flow long enough and the water will boil.
    chiefwej
    Feb 2015
    San Diego ca
    16
    Awful plumb job and pump running dry (heat)
