Results 1 to 13 of 13
Thread: coping issues
    Houston, TX
    1,104
    coping issues
    Hello to all,
    I hope this is the last of stone and other issues. Our coping is a honed travertine, and due to the negligenc of the pool contractors, our coping and tops of the spa were scratched on about 40-50% of the all the stones. I asked the PB can these be buffed out or something. He said yes.
    Getting the scratches out of the copying and other were part of the punch list. When they finished, I now have two-toned coping both as in singles pieces and as a whole. Wherever they used their sanding devices, it made the finish much lighter and has stayed like this since Monday. When you wet it, it looks as it did when it was installedl when it dries, it has a lighter duller finish to it. You can tell anywhere it was sanded due to this lighter color.
    A). Can anything be done to restore the coping back to its original look? If so, what do I have to do?
    B). If not, what do I need to tell the PB bc we still have one payment left?
    Thank you very much,
    tstex
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: coping issues
    You hold the power with the last payment. From what it sounds like, sanding all of them equally will square it up. See if you can't get him to do that.
    Essential Links:
    Houston, TX
    1,104
    Re: coping issues
    if he sands them all, then I have all defective. it looks horrible sanded. Like someone spilled baking flour on them and them smeared it
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: coping issues
    Oh man, that isnt good! I don't know what the PB will agree too, but it sounds like you want new coping. I really don't think there is a way to restore the original look unless they do exactly what was done when it was made. Wish you the best of luck, but let us know what happens.
    Essential Links:
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Re: coping issues
    Can they sand them down to a super fine finish like they do with concrete countertops? Maybe they just didn't sand it down to a super fine polish.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
    Re: coping issues
    Pics?
    18' x 36' saltwater inground vinyl pool
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: coping issues
    I was curious what it looked like myself.
    Essential Links:
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,585
    Re: coping issues
    That is NOT good I would see about them sanding them all down AND adding some kind of "polish" or finish to them BUT I would worry about it lasting.
    I guess you have to ask yourself it you want to have them replace all of the coping. Can you stand the idea of having to deal with them that much longer?
    I also would like to see a picture.
    HUGS! At least you have the last payment to hold over them!
    Kim
    Houston, TX
    1,104
    Re: coping issues
    I will work on getting some pictures.
    As stated, I want nothing more than to receive what we paid to receive. I will not accept a bandaide or temp solution as well. That also means inheriting an additional maintenance issue or the thought of it becoming defective later when my leverage is zero.
    As always, I appreciate the support & comments of the other members. I hope I can both resolve this & help out others in similar situations.
    Regards,
    Tstex
    Feb 2011
    Petaluma, Ca
    665
    Re: coping issues
    Quote Originally Posted by n240sxguy View Post
    I bought some diamond sanding discs on eBay to polish my concrete fire pit (haven't made it yet) but I did make a sample and polished up to 3000 grit, then buff, started at 50 grit, it was pretty smooth and shiny after that. It would be alot of work though as a 12" circle took about 10 / 15 min to do.
    http://www.ebay.com/itm/5-Premium-WE...item483b5ec71f
    DONE, 20 x 40, inground gunite, 30" raised bond beam with 3 12" sheer descents, 8' diving board, pentair 420 cartridge filter, vs-3050 pump, intellechlor ic-40, auto cvr, Tahoe blue pebble tech, 6ea 4' x 12.5' & 2ea 1' x 12.5' helicol solar panels, legend robotic cleaner.
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Re: coping issues
    That's what I'm talking about. If it's their mistake, let them choose to polish it or replace it.
    Jul 2012
    Tallahassee, FL
    30,585
    Re: coping issues
    You have them do what YOU want them to do!
    YOU paid for xyz and got messed up so they need to redo to get back to xyz! It will be interesting to see what the PB says and how hard you have to push.
    I feel for you! Let us know how it goes and what happens.
    Kim
    Re: coping issues
    If it looks normal when wet it sounds like it had a sealer on it.
