Thread: Whisperflo pump won't start
    A couple weeks ago I replaced the seal plate gasket on my Pentair Whisperflo 1.5 hp pump to fix a leak. It no longer leaked and ran fine for a week or two before I noticed it was not running and the breaker was tripped. Never had an issue with the pump other than this recent leak. Pump is from 2007. I'm not experiencing the humming noise before tripping, that some others have noticed with a bad start capacitor. I just get nothing. I can't get the breaker to stay on at all. Should I replace the start capacitor anyway? What else should I test?
    IGP 8500gal, Jandy Aqualink RS with IAqualink, Jandy Watercolors LED, Pentair Clean&Clear filter, Pentair Mastertemp heater, Pentair 1.5hp Whisperflo pump, A&A in-floor filtration (garbage!).
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Whisperflo pump won't start
    Something is tripping that breaker and likely it's something wrong with the motor. I suggest getting a qualified electrician.
    Essential Links:
    Citizen's Avatar
    Oct 2014
    Orlando, FL
    92
    Quote Originally Posted by jpcdmd View Post
    Usually an issue like that is sourced to a bad capacitor or the motor dying. How familiar are you with multimeter? If you are handy then checking the CAP shouldn't be too hard. Test the cap leads and also check the power source while you're at it.
    If you are no familiar with testing electrical equipment, then I would do as Brushpup suggests and get a qualified electrician
    Well I got a multimeter and tested the capacitor on top of the pump and it tested fine. I even to it to an electric motor repair shop and they tested it too. I also tested the breaker and thought the breaker was bad so I replaced it. I installed the new breaker and it still would not work.
    I pulled the breaker (with the panel still supplied with power) and reinstalled it and noticed it tripped upon seating into the panel. I flipped the switch back to the on position on and tested the breaker and could not get any reading out of it. I turned off power to the panel, reinstalled the breaker, turned power to the panel back on, and the breaker would not trip. However, no power reading with the multimeter and no juice to the pump. The impeller also spins freely. I really hate to call a professional to come look at it but I think I'm at a loss here. Any recommendations for an electrician in Phoenix?
    I replaced the motor with a refurb unit from a local pool motor repair shop. Installed it, wired it up, and It won't power up. I have a few breakers in the sub panel for the pump and pool light and a few outlets, all of which test ok at the terminal screws with the multimeter except for the breaker for the pump. It's a brand new breaker because I thought the previous one was bad. I removed the breaker and tested the contacts which the breaker sits on on the bus bar and there's power. But I can't get a reading on the breaker's terminal screws when the breaker is installed. This is driving me nuts!!!!!!!!!!!!!!!
    UPDATE....ugh I fixed it. I wasn't flipping the breaker ALL THE WAY to the off position before flipping it back on, I was only flipping it half way thinking it was off, so it was never resetting. I'm a dumba**
