Thread: Hayward H250DFN IF code problem
    Feb 2015
    San Jose, CA
    2
    Hello:
    This heater has worked fine for 4 years, but now won't stay lit, and displays an "IF" code. The heater lights normally then shuts down after a few seconds. I've done a lot of research so far and checked quite a bit. Here is what I've done so far:
    I checked the gas pressure. I have about 7" on the supply side not running, 5" while running, and 2" (exactly on spec.) on the manifold side when running. So I don't see any gas supply problem.
    I checked the orifices. I found #4 slightly blocked by spider webs, and cleaned that out. No change. All other's looked fine.
    I pulled the burner tubes and checked each one. No blockages or debris.
    I checked voltage to the gas valve. 24v, and the gas valve opens immediately when voltage is applied.
    I removed the top of the heater, no blockages.
    Following some other advice I saw online, I blocked half the holes on the inducer fan with tape. No change, removed the tape.
    With the top removed, I can see through the heat exchanger, the flame looks fine (for the few seconds it's on.) and the igniter glows bright. I don't think there is any problem with the flame itself or the igniter.
    I cleaned the flame sensor. No change.
    After all the above, I replaced the flame sensor. No change.
    At this point, I guess the control board is next. But I hate to throw parts at it. Is there anything I missed? Any other tests I can do before buying parts?
    Thanks, Larry
    Apr 2014
    Hackettstown, NJ
    35
    Re: Hayward H250DFN IF code problem
    Quote Originally Posted by larrymb View Post
    Hello:
    Thanks, Larry
    judging by the context you are giving about your problem I'm guessing you have a flame sensor that wires to the control board and some sort of electric/electronic ignition. (as opposed to a thermocouple type with a standing pilot) that being said, handle that type of flame sensing rod carefully, and don't ever touch it with bare hands, use gloves. It is sensitive to skin oil like a halogen bulb. also when cleaning them I only use a piece of steel wool, nothing else. if you replaced it and the new one didn't get contaminated, then I'd agree that the board is probably dead. I remember there was a way to test that sensor electrically, but don't remember exactly. I think it was DC Milliamps you were looking for, but can't be certain.
    25.5K gal vinyl IGP 3.5' - 8' depth. 1.5HP single speed A.O. Smith C48L2N134B1 motor on a Hayward SP2610X15 Pump. 40 ft2 D.E. Filter Hayward model EC75A. Hayward Chlorinator model CL200. single skimmer, 2 Returns. TF100 Test Kit/Speed Stir.
    ps0303's Avatar
    Jul 2011
    FL
    3,689
    Usually cleaning the flame sensor doesn't do much. A flame sensor is cheaper than a board so start there first. Now if that doesn't work, the board is next.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Hayward Pool's Avatar
    Oct 2014
    Elizabeth
    426
    Hi This is John the Hayward tech. You have already done everything I would do checking to find out why the FDN will not light. Based on your information I would say it is either the fuse board or most likely the main control board.
    Hayward Pool Tech
    80+ Years of Technologically Advanced Pool Product Manufacturing
    poolside@haywardnet.com
    Feb 2015
    San Jose, CA
    2
    Followup: I replaced the control board and the unit works fine now. While I am happy that the unit works, I am frustrated at what looks to me like a design with an overly sensitive calibration. I don't think anything was wrong with the board other than a component drifted a bit, moving the flame sensor calibration out of range.
    ps0303's Avatar
    Jul 2011
    FL
    3,689
    larrymb, what happened to you has been happening to lots of Hayward customers on this style heater. It has gotten so I no longer recommend these units to customers. It's really a shame as Hayward is such a good company but they drifted way out of wack with this heater. I have also sen these units have leaky heat exchangers after as little as 18 months.
    Paul
