Thread: Heater question....Probably a simple answer
    May 2014
    Clarksburg, WV
    331
    My neighbor just bought his house. It had a pool with a heater. He is selling the pool and heater. I'm interested in the heater. Its setup right now for propane, but I have natural gas. Are these heaters like most indoor heaters and a kit can be bought to convert from propane to natural gas?
    Or does it completely depend on the make/model of the heater......Which right now, i have no clue about.
    While i'm in discussion about this heater. It has been sitting out beside the pool for the past 2 years unused. Anything special I should look for to make sure its in good shape and in working condition?
    24'x54" 15k AG round - Outback Genesis
    1 1/2hp Hayward Matrix 2 speed. Hayward 180T Sand Filter
    TF-100 Test Kit
    Pool School & TF-100
    How to SLAM
    Re: Heater question....Probably a simple answer
    Walk away
    Used heaters are chancy. Gas heaters are very sensitive to maintaining proper PH, and you have no way of knowing if that was done or not and no easy way to inspect the heater to get a clear indication of problems in that area. Still, if the price is right
    Conversion between propane/natural gas is normally very easy.
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    If the price is right go for it. Should just be a jet to swap out. If you back out, let me know what he wants for it.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
    Mar 2011
    441
    Quote Originally Posted by kris77 View Post
    It really depends on the heater. Most require a gas valve replacement (or regulator springs) and orifices. Some heater like the pentair master temp only require an orifice.
    20X40 30,000 gallon gunite pool
    May 2014
    Clarksburg, WV
    331
    Quote Originally Posted by stebs View Post
    Walk away
    This was my first thought. Waiting till the snow melts to go take a look at it and see what kind it is and how old and etc.....
    Just wondering if the conversion was as simple as a wall mount garage heater or a gas stove or anything else like that.
    TF-100 Test Kit
    How to SLAM
