Thread: Polaris getting stuck...
    Aug 2014
    So cal
    17
    Dog got to old hose, so we got new black one, keeps getting stuck... Any ideas, thanks.
    (thanks for helping with youtube embed)
    16k pool/spa clean & clear filter Polaris auto cleaner ecoStar pump
    Aug 2014
    So cal
    17
    Re: Polaris getting stuck...
    Seems like the wheels are turning
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Step 1. Beat the dog with old hose.
    Step 2. Call Polaris to see if there is a difference in white and black hose. It may be a different diameter so the reverse nozzle isn't being activated.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
    Aug 2014
    So cal
    17
    Quote Originally Posted by n240sxguy View Post
    Is the reverse nozzle the little jet in the back? there is a lot of water coming out of that... The back up valve is working as well.
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Quote Originally Posted by scannon View Post
    I meant the back up valve. Mine usually has a decent stream coming out the little nozzle on the back, and every couple minutes the back up valve fires for probably a minute.
    H-12 1/2 Mike's Avatar
    Apr 2014
    Highland Village, TX
    75
    Mine always gets stuck at the steps but the back-up valve usually clears it. It looks like there is an awful lot of hose attached, it should only allow the Polaris to just reach the farthest corner. Also, have you tried to change the direction of the nozzle from the 11 o'clock position to the 1 o'clock position
    16,400 gallon
    Cartridge Filter
    IG
    Intelli-Flo @ 2000rpm
