Thread: Need Plumbing Advice
    Oct 2014
    Sacramento, CA
    72
    So today I have encountered my first plumbing problem I have ever had I have done 100s of skimmers and never had this tight of a spot so I'm working on a pool I cut a 3x3 hole in the concrete to replace a leak it's a T fitting cracked by a tree root I litterally have no room to work has anyone ever used compression fittings on a pool or is there some type of 2" and 1" slip couplings for extremely tight spaces I have never had this issue before and I'm at a loss
    David Randolph
    Warranty Station
    Pentair
    Jandy
    Owner Sac Pool Pros
    Re: Need Plumbing Advice
    Compression fittings will work for a while, but generally leak after a few years. They aren't really designed for pressure applications and chlorine can break down the gasket given time. As a temporary patch they will usually work till something more permanent can be arranged, but I wouldn't use one for a permanent fix.
    An inside slip connector might help, depending on the details of the situation. They are much like an regular slip connection, but go on the inside of the pipe instead of the outside. Because of that, they can nest half way inside some other connection. For example if you have two fittings with no extra pipe between them that has to be cut apart temporarily, you can often reconnect the connection with an inside slip connection.
    Mar 2011
    441
    Do you have pics of the problem? If you need a shorter coupling couldn't you just cut one down?
    20X40 30,000 gallon gunite pool
