Thread: Anyone ever try this product...?
    Jan 2015
    Fuquay Varina, NC
    22
    I was just checking on algae control and shock prices in anticipation of slamming the green velvet coating on my pool this spring.
    I ran across a product called GreenCleanMax: http://www.newtechbio.com/catalog/in...roducts_id=222
    I called the company out of curiosity and spoke with one of the reps. He explained that you add the stuff - and recommended adding more than required to open a pool - since it doesn't upset the chemistry.
    Evidently - it foams up, lifting any leftover leaves etc off the pool bottom in the first 15-60 minutes of treatment. You skim until you've gotten rid of most of the stuff, then kick on the filter and resume chlorination after a couple of hours of circulation. The algae is gone within a few days.
    For my pool - I estimate about $90.00 with shipping. I suppose I'd still get a couple of cases of shock to complete the job.
    Has anyone ever tried this stuff?
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Anyone ever try this product...?
    It's peroxide. Not worth the effort. Chlorine is all you need.
    Jan 2015
    Fuquay Varina, NC
    22
    Thanks.
    After posting I was thinking that I wouldn't need $90.00 worth of shock to get things cleaned up.
    38,508
    I am not sure what you are referring to when you say "shock". You do NOT want to use an solid forms of chlorine. You need to stick with liquid chlorine / bleach and follow the ShockLevelAndMAINTAIN Process to a tee. The SLAM is guaranteed to work every time ... unlike the pour and pray method that pool stores tend to recommend.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,058
    Search box says you're the first. https://www.google.com/search?sitese...y=9&gws_rd=ssl
    Casey's Avatar
    SW PA
    10,457
    Don't waste your money.
