Results 1 to 7 of 7
Thread: Understanding Leslie's DPD Kit
    Jan 2015
    austin/tx
    34
    Unfortunately I bought this $75 kit before finding this forum. I'm sure it's fine and I will get the recommended additional kit. I have tested the CYA several times and that black dot NEVER disappears. It does fade.
    Also, the chlorine reading - it appears the TC and FC are the same, so my reading is zero? I might not understand how to read the comparator tube. They both read as 3. My pool water is clear.
    I am asking because I have another question and I know you will need the chemistry. Here's the other question:
    The Aqua rite chlorine generator lights are all off and cannot get a reading. I have learned through this forum to change the "black quarter" part. I have ordered the part and am waiting. I also found the yellow wire to the fuse is burnt and changed the connector. The board is 2 years old according to the prior owner and it worked until we started trying to fix the pool light (install relay and hook up wires). Pool light is another question for another day!
    PH is 8 with 1 drop to restore to 7.4
    Calcium turns red with 20 drops to turn purple.
    alkalinity is 60ppm
    I have a cartridge filter - not clay. need to change my signature.
    Austin, TX in ground 28,000 Midnight Blue regular pebble w/ abalone pool and spa, Aqua Rite Chlorine Generator, Cart filter, Jandy Niceless lights, Aqualink automation, Leslie's DPD test
    Jan 2015
    austin/tx
    34
    Re: Understanding Leslie's DPD Kit
    Attachment 34306Attachment 34307
    The blower is not attached to the pipe as the former owner did not connect to a relay. If we connect it to a relay do we need to attach it to the pole somehow? Water is always around the bottom of the filter. When we have gotten the pool light to work the water looks a little green at night. Is that the bulb?Attachment 34308
    TC - FC = CC, so your CC reading is zero, which is a good thing. The number you usually monitor is FC, which is read directly from the test.
    Your PH is a little high, you should lower it just a little, say to 7.5 or 7.6.
    The CH test turning purple is called a fading end point, you can read more about that [url=http://www.troublefreepool.com/threads/24188-Extended-Test-Kit-Directions?p=203523&viewfull=1#post203523]here[url].
    Jan 2015
    austin/tx
    34
    Well that's a relief considering the chlorine generator has not worked for a week. If the chlorine gets low while we are waiting for the part, can we add bleach manually?
    Meanwhile I'll add muriatic acid to lower the PH.
    So happy I found this forum! Thank you.
    Yes, adding bleach as needed manually is a great idea.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,005
    Hi Colorfaux,
    regarding the water around the bottom of your filter.
    Its likely coming from the drain plug
    Directly below the pipes all the way on the bottom is an inset in the filter housing. In that inset is a drain plug.
    It either just needs a tweak of tightening, or perhaps the O ring on the plug got damaged, or maybe the o ring just needs some lubrication on it. But its my bet thats why there is water around the filter.
    Divin Dave,
    38,455
    Sounds like you are off to a good start. I do highly recommend you add the recommended FAS-DPD Chlorine Test to your kit though.
    I don't think anyone addressed your CYA question. If the dot does not disappear when doing the test outside with your back to the sun, then you CYA level is low (< 20ppm). Your SWG will work less if you bumped that CYA up toward the recommended 70-80ppm: Water Balance for SWGs
