We are still in the punch list phast of our pool, and they had to drain it about a 1-2" below where the pebblesheen meets the tile water line.
I would assume the autofill water line has been disabled, and wanted to get it work again instead of running the hose inside pool. How do you get the auto-fill to wk again?
Also, I was told to take out of service mode at noon today and start pump again for cirulation. I did so wout thinking the water line was below the skimmers. I went back and turned off the pump-filtering system, but wanted to know did the pump cavitate or will the return lines refill w water as the skimmers fill? If not, do I need to bleed air out of the return water lines or other?
Thanks you,
tstex
Thanks you,
tstex
