Results 1 to 8 of 8
Thread: Just Bought A House With ......
    Jan 2015
    austin/tx
    34
    a Saltwater pool!!! Excited. However, some things are going wrong. I will be asking questions and have already learned a lot from the pool school.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,005
    Re: Just Bought A House With ......
    Welcome to TFP!
    As always, ask away!
    Divin Dave,
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Welcome to TFP !
    If any of your questions are on water chemistry we need accurate test results to give you good accurate advice on. The way you get accurate test results is with one of these Test Kits. The TF100 is the best bang for the buck and the one I use.
    Keep reading in Pool School. Here is a good article.
    ABC'S Of Pool Water Chemistry.
    When you have questions ask away !! Hope you enjoy the forum.
    Jeff
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,099
    Welcome to TFP! Can't wait to help you with your questions!
    mrcarcrazy's Avatar
    Jan 2014
    Odessa, TX
    977
    Welcome to the site. Enjoy the learning process.
    IG gunite/plaster pool/spa Started 1/17/14, Plastered 5/16/14
    Size: 12'-21'x39' free form, depth ranging from 4' to 7, attached 6 person spa with spillover.
    Equipment: Whisperflo 2hp pump, Pentair 30" sand filter, Pentair Mastertemp 400k BTU heater, 1hp Whisperflo for waterfalls, and a blower for spa floor
    pragmatic's Avatar
    Jul 2011
    Friendswood, TX
    521
    Welcome to TFP! You found the perfect spot for solutions to all your pool related issues.
    Dave My Pool Build, ODK Build
    22X42 Gunite Freeform 23K Gal, 10X12 Spa
    Diamond-Brite midnight blue, 1800sq. ft Kool Deck
    Pentair Easy-Touch 8, 2-2hp Pentair, 500lb Sand Filter, 400K btu Pentair heater
    Sep 2013
    Dallas-Ft. Worth Metroplex, TX
    810
    Welcome!
    14K Freeform Gunite w/60% Blue Quartz plaster, Quad DE filter, Intelliflo VS Pump + Booster for Cleaner, Aquacal Heat Pump
    Casey's Avatar
    SW PA
    10,453
    Welcome!
