Thread: Reglueing tiles underwater
    San Juan Cosala, Jalisco
    53
    I imagine this has been discussed before but I can't find it. I have several individual tiles that have come glue. Can anyone recommend a glue that can be used underwater to glue them back in? I found one but it is blue and it looks awful as my grout is white. I need a white one.
    Re: Reglueing tiles underwater
    This stuff should work well.
    30,421
    You may be out of luck. Never heard of anything that will work well and still look acceptable.
    mas985's Avatar
    Pleasanton, CA
    11,737
    I have used this before: http://www.homedepot.com/p/J-B-Weld-...vZc5dkZ1z0t5fs
    It is a putty so easy to use underwater and it drys off white.
    Mark
    mikespoolfl's Avatar
    Mar 2011
    Florida
    179
    I’ve used the water weld one about 5 years ago and still holding up. If you really careful you can use it to fill the grout line also
    Screen enclosed 17K gal 16x30 IG with Diamond Brite finish, elevated 4 jet spa with spill over, Twin dolphin fountain, Hayward Ecostar pump[ Pentair intelliflo VS, Filter Sta rite Posi-Flo PTM 100, Aqua Cal heat pump, Tiger Shark QC robotic cleaner.
    Stenner peristaltic pump model 45MPHP10, 15 gal storage tank. TF 100 with Speed Stir.
    53
    Thanks. I will give the Water Weld a try.
