I would suggest that you look for a licensed master electrician. Explain what the issues and situation are and ask if it's something they have experience with and are confident that they can solve.
Also, the breaker quality is not the only issue. Variable speed drives create harmonics that can cause certain types of gfci breakers to nuisance trip. If the breaker is not designed and rated for vsp use, it might not work regardless of its quality.
Another thing to look for would be neutral to ground stray currents. A good electrician should be able to check for those types of things.
