Re: Breakers keep tripping
Well, the saga continues w the breakers tripping.
This morning the pool did not start up as programmed by the PB at 9am CST. I went to the control panel and the message said something like "filter error". I cannot recall the specifics, but when I looked down, both of the double-polled 20amp breakers were tripped. again, even after a new GCFI was installed.
Both of DP 20Amp breakers are Siemens and both have white test buttons on them. It seems one id dedicated to the hayward Ecostar pump and the other 20amp is dedicated to the heater, blower, Hayward Super II 1.5HP pump. The lights are on a separate 15amp and so are the fire bowls.
The VSP shut off yesterday at 3 as programmed, but did not come on this morning, along w the filtering system. Nothing else was being run, so I am thinking along the lines that it has to be:
1). Bad breaker for VSP
2). Short in the VSP
3). Bad computer panel
Since both breakers are tripping, and the VSP is only hooked-up to one of the 20AMP breakers, could one breaker tripping cause the other one to trip or a bad pump cause them both to trip? If not, then I would assume it is something highter up and that is the control panel.
I sent my PB a note on the matter and awaiting a response. Any feedback prior would be greatly appreciated so I have some retort when we talk.
As always, thank you very much,
tstex
tstex
