Thread: Plaster mottling
    Nov 2014
    Palm Desert, CA
    99
    Plaster mottling
    What is an acceptable amount of plaster mottling? We had our pool replastered 10 days ago. Before they started filling the pool I noticed some creamy beige mottling on some of the walls but thought that was normal because it was wet, fresh plaster. I was thinking it would dissipate when the pool was filled and curing over time but it's been 10 days and no better. It is basically over the whole pool (bottom and sides), might have been like that before filling pool but I'm not sure, I remember seeing it on some of the walls but thought everything looked really good. It's not terrible and only really noticeable when the water is still but there is definite mottling. Also, the pool guy who was doing our start up came the first day after filled (Thurs) and added acid. He came back two days (Sat) later and added acid, but he has been a no show since then. I took over testing and added acid on Wed and again yesterday Friday. I just added chlorine today and am going to wait to test before adding more acid. Could the erratic start up have caused this mottling or made it worse?
    17,000 gallon inground pool; Plaster redone January 2015; Pentair Cartridge Filter; SWG; Age of pool unknown (house built in 1973); Taylor K-2006 Test Kit.; Doheny Discovery robot cleaner.
    Sep 2013
    Dallas-Ft. Worth Metroplex, TX
    810
    Re: Plaster mottling
    Did the plaster company give you any startup instructions? What type of warranty did they give you?
    14K Freeform Gunite w/60% Blue Quartz plaster, Quad DE filter, Intelliflo VS Pump + Booster for Cleaner, Aquacal Heat Pump
    Nov 2014
    Palm Desert, CA
    99
    I have a 3 year warranty. The plasterer said my warranty was good whether I did the start up or the pool guy. I've tried to attach photos I took when the pool was freshly plastered and getting filled with water. I thought the mottling would go away as it dried, and at the beginning I kept thinking the mottling on the floor was the plaster dust settling as I brushed the pool. Any opinions if this is the plasterers responsibility to correct? He is coming over Mon or Tues to deliver my eyeballs that were on backorder. Is it as simple as draining the pool and doing a light acid wash? After Plaster 3.jpgAfter Plaster 3.jpg
    Sorry for the duplicate photo. It should have been this one.After Plaster 8.jpg
    Sep 2013
    810
    I believe it is his responsibility to make the brand new plaster look good. An acid bath can be done without draining.
    Nov 2014
    Palm Desert, CA
    99
    I was thinking you needed to drain the pool for an acid wash so that makes me feel better, thank you! Any opinions if this could be corrected with an acid wash or just due to poor workmanship? I've seen online where it can mottle if they work the plaster too much when it's too dry. Is it possible it will fade over time as the plaster keeps curing? I'm just not sure on what is "normal" for a plaster pool.
