Results 1 to 12 of 12
Thread: Need Help with hayward filter settings
    Jan 2015
    Portola Valley, CA
    3
    Hi
    New to this forum and trying to figure stuff out for myself. I had new pool equipment installed a year ago and the settings that the installer used are costing me a fortune in electricity bills and i want to know what settings i should be using to run the equipment for the right amount of time at the right speed.
    here is what i know my setup is
    Hayward ecostar pool pump
    hayward ecommand 4 control box
    Approx 25,000 gallon pool
    Right now its set to run for 8 hours a day in winter at full speed which looks to be about 3105 RPM which based on the website basically says that is 90% or about 144 GPM (equipment is about 30ft from pool)
    Reading the manuals it seems to imply that the pool should run a mixture of high and low speed. I've contacted the installer who basically told me that i should just reduce the pump speed, but he didn't give me a real high level of comfort that it was right. So any help would be very much appreciated. I've attached some pics of the set up.
    30,432
    Re: Need Help with hayward filter settings
    There is no magic formula for exactly the right amount of run time. However, you are running yours w-a-a-ay too much.
    I would set the speed around 1500 rpm (others with more knowledge may tweak that number a bit) and probably only run the pump about 4 hours daily. You have to determine the runtime. All that's required is enough run time to keep your pool clean.......in the winter, that should be enough or close to it.
    In the swim season, you will run it longer and probably a little faster, depending on how much "load" (swimmers, dirt, etc.) you put on it.
    Again, the final determination is yours. Run it enough to keep it clean but no more.
    Jan 2015
    Portola Valley, CA
    3
    Thanks, is there anything special i should be doing with my pump given that its a variable speed pump vs fixed. Their website seems to imply it runs for longer period of times but uses a lot less electricity.
    Jan 2015
    Portola Valley, CA
    3
    i also just got an email from the manufacturer that says i should run the pump for 16 hours a day at 600-800 rpm's
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    600-800 May be a bit too low. Just to give you an idea of the kind of savings lowering the speed will achieve, my 3 hp Pentair pump draws over 2,500 watts at max speed, but at 1,000 rpm it uses about the same power as a single 100 watt light bulb.
    chiefwej
    mas985's Avatar
    Pleasanton, CA
    11,743
    For the EcoStar maximum efficiency measured by Gallons per Watt is around 800-900 RPM. But that may or may not be fast enough for certain things like skimming and cleaners but I wouldn't go below 800 RPM because efficiency starts to drop again.
    Mark
    Mod Squad pooldv's Avatar
    DFW, TX
    24,516
    I have run my pentair 3hp variable speed pump at 1100 rpm 24x7 365 for over 3 years. It pulls about 150 watts at this rpm. This provides the 24 hour skimming action I need for all the trees. This also lets me set the swcg at 20-40% since it is always making chlorine. My Solar Touch turns the pump up to 1950 when the sun is out.
    150 watts times 24 hours is 3.6kWh per day x 10 cents per kWh is 36 cents per day. 30 days is about $11 per month.
    You should move your time and speed way down and move it up as needed if the pool isn't staying clean.
    Jan 2014
    Buckeye AZ
    807
    Quote Originally Posted by mas985 View Post
    where do you get the "best rpm for efficiency" rating? Is that like a graph somewhere for each model?
    10,500 gal IG, Topaz Pebble, auto-level
    Hayward DE filter, 2HP Ecostar VSP, ProLogic PS-4, GVA actuators
    Cal Pools Wave Force Plus (wall return jets plus 2 floor pop-ups), Venturi Skimmer
    Water sheer, 2 wok pots, bubbler stem on the baja step
    ColorLogic Mutlicolor LED lamp. Taylor 2006+speed stir
    mas985's Avatar
    Pleasanton, CA
    11,743
    It is based upon pump measurements. I have several spreadsheets (see sig) which use these measurements to calculate operating points for any type of plumbing.
    Mark
    ssml11's Avatar
    Jul 2014
    Miami/Florida
    131
    I have the same pump. 3000 rpm is overkill. I would only crank it up that higher if you a case of algae/dirt and need to shock pool quickly.
    For everyday circulation I wouldn't get passed 1300 rpm. Just resign you your speed to that setting should represent substantial savings.
    Just curious, since you are blaming the new pool for the increased electric bill, by how much did the monthly bill increase after pool?
    Feb 2015
    San Diego ca
    16
    1500 rpm and 10 hours a day is what I'd start at and go to maybe 8 hours if you can for winter time
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    As Dave suggested, you can likely get away with pretty short runs in winter.
    Essential Links:
