Page 1 of 2 12 LastLast
Results 1 to 20 of 27
Thread: Cloudy Water - SLAM Question
    Nov 2014
    Australia
    78
    So, my test kit arrived and I've managed to get a few things sorted in my little pool. One thing is the cloudy water is a persistent problem. Here are my latest test results from this morning:
    FC - 3.5
    CC - .5
    PH - 8
    TA - 110
    CH - 0
    I am now using Hy Clor Liquid Chlorine which has 125gms/litre (12.5% available chlorine) - 800ml was added last night, the recommended daily dose is 200ml
    I did add 500 ml of Hy Clor liquid stabilizer to up the CYA - (active constituent is Monosodium Cyanurate monohydrate) The recommended dose for 25000 litres was 2.5 litres, my pool holds approximately 10000 hence the 500ml.
    I'm going to add another does of liquid chlorine now and see if that helps. My filter is running constantly from 10am when the sun hits the pool right round until 7ish in the evening. I do have it covered to stop stuff falling in it but the cover is a mesh and sunlight still gets through.
    Any help is appreciated.
    2014 to 2015m pool 10000 litre (2531 Gallons) Bestway Above Ground Pool 412cmx201cmx122cm (162"x72"x48"), 1000GPH Sand Filter Pump System
    2016 New Pool - 3mtrx5.6mtr 20,000 litre Oval Above Ground, 21" Ongar Sand filter with 550 watt pump. (being sunk 60cm inground)
    30,424
    Re: Cloudy Water - SLAM Question
    What is your current CYA test result?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,027
    What was the CYA level prior to the addition? Poolmath shows 500 ml of liquid stabilizer raising CYA by 18 in a 10000l pool.
    Forget recommended doses. Use your test kit and poolmath to figure out exactly what your pool needs, no more, no less.
    Nov 2014
    Australia
    78
    Thanks for the replies, the CYA is still showing as 0, sorry, I should have put that in my first post.
    I'm using the Taylor K2006 test kit, I think I'm doing it right, it says to add the two chemicals to the small sample bottle and then empty that into the small test tube until you can't see the dot. I'm assuming the water is supposed to be cloudy for that test but mine is perfectly clear and even filled up I can still see the black dot.
    I've read quite a few topics re cloudy water and CYA on here and most of them say that it can take up to a week to register.
    I added 550ml of the liquid chlorine last night as per the pool math calculator, it also said to add another 811ml of stabiliser - I really wanted more advice before adding more.
    Just tested the water again and here are the results:
    FC - 3.5
    CC - 0
    PH - 7.8 - 8 ( I think I'm a bit colour blind )
    TA - 120
    CH - 0
    CYA - 0
    Richard320's Avatar
    Jan 2010
    19,027
    If you're in the SLAM process, the 18 CYA calculated is fine. You just need to maintain 10 FC until you pass all three tests. Note that when it says the water is clear consider that after brushing! Once the SLAM is done, then you'll want to raise it to something more like 50 CYA.
    aussieta's Avatar
    Jan 2014
    Langwarrin, Victoria, Australia
    488
    do you really have 0 calcium hardness or did you not test
    SWG inground peanut shaped eco-bright concrete pool
    50,000 litres 13,000 gallons
    Lincoln Salt Chlorinator, 25 gram cell Sand Filter with glass media
    Taylor K2006-C test kit, Taylor K-1766 salt test, Dolphin M500 pool cleaner
    are you taking care of your pool or is the poolshop taking care of you
    Nov 2014
    Australia
    78
    Sorry again, the CH should have read CYA - 0 the CH is (or was) 220
    I have gone back printed out and re-read the SLAM info, now I see what it means to keep the level up to 10 - my mistake.
    FC - 11.5
    CC - 0
    PH - 8
    TA - 120
    CYA still 0
    CH - didn't test this time
    I'll go out and brush the sides again tonight and put the vacuum in tomorrow morning. According to the pool maths I need to now add 42gms of dry acid and 326ml of liquid stabiliser which I'll do now.
    Thanks for your help, sorry to be such a wally - when that test kit arrived I thought all my problems would be over - silly me.
    ETA - so I found out why there is no CYA reading. When pouring it into the jug for measuring the first time, all that was poured in was clear liquid - the bottle needed shaking up to mix it DOH! It wasn't me pouring it in so I don't feel that stupid. All sorted now, shook the bottle, measured out the required amount as er pool math chart and hopefully in the morning I will get a reading.
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    Pics please Mollyj..... And yes liquid CYA here is clear liquid on top of white liquid... Shake them really well....
    Intex Rectangle 18 x 9 x 52', 4544 gallon (18000 litres), 0.75 hp pool pump, 100 sqft Zodiac Titan Cartridge Filter - 40mm, Stenner Peristaltic Pump chlorine injection system, Intex Over The Wall Skimmer, Intex Fittings with 40mm plumbing Lil Patch Of Heaven. Build/Construction http://www.troublefreepool.com/threa...lice-of-heaven
    Nov 2014
    Australia
    78
    I added piccies to the other topic Laceygirl - and yeah, lol, lessons learned with that stupid liquid
    Richard320's Avatar
    Jan 2010
    19,027
    Don't get too excited about the pH reading, and don't rush to add acid, either. High FC reacts with the test reagent and makes it read falsely high, which is why the instructions for the SLAM say to adjust pH first and then ignore it. Here's an interesting thread with pictures that shows what happens to the pH reading (not the pH itself) at high FC. http://www.troublefreepool.com/threa...els-with-R-007
    Nov 2014
    Australia
    78
    Thanks Richard, this is such a learning curve - chemistry wasn't on my list of subjects at school, the tests are all making sense now - although I think reordering the refills is going to be expensive It's great to have almost instant advice though, you guys are soooo helpful
    Todays results are:
    FC - 8 going to add more chlorine now
    CC - 0
    PH - 7.8
    TA - 110
    CH - 320
    CYA - still showing 0 - might be because I didn't add enough yesterday - not going to add anymore today, I'll just stick with the liquid chlorine.
    The good news is that the pool is already looking cleaner - today is a bit cooler so I'll vacuum, brush the sides and put my net cover on. By tomorrow, I'm hoping to see the bottom again.
    Casey's Avatar
    SW PA
    10,448
    Keep up with the SLAM Ms Molly and your pool will clear. It takes time and a good brushing every day while in the SLAM process. I like to brush my pool twice a week when the pool is looking it's best. It helps get the fine sediment off the floor and walls, and then I'll vac the next day. If you're still showing zero CYA in a few days, you can add more CYA to get that up. Good Luck!
    Nov 2014
    Australia
    78
    Thanks Casey, it's hard not to get despondent when the water is still so cloudy. I've had the pump running constantly every day, vacuumed today, brushed the sides and bottom again this morning and am keeping the FC up to 10 - thats the hard bit with the sun shining. Fingers crossed that it looks clearer tomorrow.
    I'm so going to keep a closer eye on things from now on.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    You can take your FC up to 12 if you like. That will help with the FC burn off from the sun.
    Sand filters sometime take a little longer to get the cloudiness cleared up. Give it a few more days and if there is t any improvement you can try this. Adding DE To A Sand Filter.
    Jeff
    30,424
    With 0 CYA in your pool, the SLAM process will consume your FC voraciously and will make it tough to get your pool clear.
    1. Have you read "The ABC's of Pool Water Chemistry" up in Pool School? Do you understand the purpose of CYA?
    2. Have you used Poolmath to calculate the dosage of CYA and bring it up to around 30 ppm?
    3. How much CYA have you put in your pool to this point? What do you think your CYA should be?
    Nov 2014
    Australia
    78
    I did add more liquid stabiliser to the pool last night as per poolmath. This morning the FC was showing as 15, now thought, with the cover off, a top up of water and pump going all day, it is looking a little clearer.
    FC - 10
    CC - 0
    PH - 7.6
    TA - 100
    CH - Didn't test this time
    CYA - is still below 30
    I have read Pool School and feel like I'm drowning in information. I've also read heaps of topics on members with cloudy water and most of them say that it can take a while for the CYA to show up.
    From my understanding this is what my levels should be after the pool is clear:
    with Bleach
    FC 3-7 (See chart)
    pH 7.5-7.8
    TA 70-90+
    CH 0-350 (Don't add)
    CYA 30-50
    I think I've been underestimating the amount needed - Poolmaths says to add 268ml of stabiliser and 200ml 12.5% bleach - so that's what I'll do. I just re read the pool school topic on CYA and now understand that a lot of direct sunlight can make a whole heap of difference - we get a lot of sun on the pool all day. (temps over 30degC all this week)
    I'm also running out of the chemical to test the CYA - is there another way of testing it ? I'll re order more today but it will take a while to arrive from the US.
    I do have DE - two big 5kg bags (we use it to help with flea control with our cats) although it is the food grade one, so maybe too fine. Also, is it likely to make the pool cloudier?
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Your CYA level should be pretty accurate within 24 hours with the pump running since your using the liquid form. It's the granular form that can take sometime to fully register on the test. Would you say your CYA level is close to 20 ?
    Yes the info can be a little overwhelming at first, but you seem to have an understanding of where your levels should be when your pool gets cleared up.
    Don't use the food grade DE. Use pool grade DE if you decide to try adding it to your filter. It's not a must do. Your sand filter is up to the task.
    Jeff
    30,424
    Your total amount of liquid CYA you have put in the pool should be around 800 ml. That'll get you 30 ppm....how much have you put in?
    If you have added measured doses, you don't need to test but rather can assume your CYA is, in fact 30 ppm.
    Skip the DE for now.....it's only going to confuse you further.
    FC 3-7 (See chart)
    pH 7.5-7.8
    TA 70-90+
    CYA 30-50
    Those are good values. Keep your FC up, run your pump 24/7, backwash as necessary and your pool will continue to clear.
    Nov 2014
    Australia
    78
    Thanks folks, it's all really helpful advice and I do feel like I'm getting a grip on it now. The pool was looking much better yesterday - until I brushed the walls lol
    The confusing thing with the stabiliser was adding the clear liquid (bottle not shaken) so I thought that 500ml had been added, when in fact nothing had, so that wasted time and testing stuff. I have since added 562ml as that was what the pool math showed, should I add more?
    Today's readings:
    FC - 11.5
    CC - 0
    PH - 7.6
    TA - 120
    CH - 300
    CYA - tested using a test strip this morning (I know, not accurate but I've run out of the liquid tester) it shows between 20 and 30.
    Think I'm making headway.Just a couple more questions -
    should I add more stabiliser?
    should I add more liquid chlorine this morning?
    Should I be worried about eh TA being 120?
  20. Back To Top    #20
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    When you added the 562ml go with what pool math said that would bring your CYA level to.
    Jeff
