Thread: pH is high after SPA heating cycle
    Hello All,
    Thanks in advance for you help. I've just started up my SPA and trying to balance pH and TA before I pour in the start up bromine and stuff. I got the TA and pH to desired level but pH is high after SPA heating cycle. I've set my SPA to heat (slow speed) between 9PM and 6AM, and when I check the following day, pH is really red. TA is at same level. Why is pH doing this? I know about the aerate increasing pH but none of the jets are above the water line. I use acid to lower pH to 7.2, but it goes high again after SPA heating cycle. TA is good. I can't keep adding acid everyday because acid will also lower TA and then I need to add baking soda to raise TA and it's just a infinite loop. Please help. Thank you.
    16k gal, IG pebble tech,DE #, 1/2HP
    Re: pH is high after SPA heating cycle
    Welcome to TFP!
    What is your TA? Assuming this is a stand alone spa, you TA is probably too high. The ideal TA for a stand alone spa is the highest TA where what you describe does not happen.
    Quote Originally Posted by JasonLion View Post
    Welcome to TFP!
    TA is 80. This is above ground SPA, I filled it about 360 gallons. As I remember, Taylor test kit recommends TA range from 80-140
    A TA in the 80 to 140 range is too high for a spa. Try 60 ppm or even slightly lower if necessary. Also try keeping the pH at about 7.8.
    Support the site
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,013
    Quote Originally Posted by ithelpme View Post
    Play with poolmath a little. See how lower TA decreases the acid demand to effect a certain pH change. And then on a practical note: adjust pH. Keep adjusting it. You will notice over a few weeks that as TA drops, acid demand drops, and pH remains in range for longer periods of time. That's the sweet spot. Who cares if it's 65 or 100; every pool/spa has a unique personality. If pH holds steady at a certain TA, that's where you want it.
