Results 1 to 17 of 17
Thread: Pump motor DIED, what to replace it with? (Solar)
    FlyAU98's Avatar
    Jul 2014
    Ft. Lauderdale, Florida
    59
    Angry Pump motor DIED, what to replace it with? (Solar)
    My pump motor is starting to make noise that I think may indicate the bearings are going bad.
    The house/pool are new to me, so I don't have any background on the equipment selection (listed in signature).
    Its a single story house, with the solar panels on the roof.
    The pump is controlled by a standard intermatic mechanical timer, which could also stand to be replaced. It isn't pretty and the latch is rusted away, but it works fine.
    I'm interested in a two-speed or variable speed pump, but easily open to staying with a single speed.
    I looked at the link in another post that showed how to replace the bearings...I don't know the age of the motor, but it has some time on it. I'm probably more interested in just replacing the motor (and pump if I should) than trying to replace the bearings and reinstalling the old motor.
    But I have no idea where to start, other than doing a direct replacement of what is there (1hp single speed pump), primarily because of the solar panels.
    My future plan for the equipment is to add a Stenner pump for the Chlorine once I got around to having an electrical outlet installed at the equipment pad...although sometimes I think I should just bite the bullet and switch to salt instead of the Stenner. Perhaps this is a time to knock it all out.
    15.5K gal, concrete, 1HP AO Smith pump, Hayward C1200 cartridge filter, Zodiac T5 Duo auto cleaner, 8 panel solar heater controlled by Hayward Aqua Solar GL-235
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Re: Pump Motor Going Bad? What to replace it with?
    You can get a new housing for the timer. The Intermatic mechanical timers are pretty bullet proof.
    Depending on the pump you can remove the motor and backing plate and bring it to a local pool store they'll mount a new motor and just re-install.
    What's your DIY level?
    FlyAU98's Avatar
    Jul 2014
    59
    I think replacing the motor or complete pump/motor is well within my capability. Where I'm struggling is in the decision about direct replacement of an identical single speed, or making the two-speed/variable speed jump. The solar panels seem to complicate that.
    Apr 2011
    Murrieta, CA
    2,360
    When you are running solar you'll want to be running on high speed. Is your system 120V or 240V? Will the aqua solar do switching? https://www.hayward-pool.com/pdf/man...olarGL-235.pdf
    I'm not positive, but I think you can wire a 2 speed motor for low, then when the solar comes on it will switch it to high. That might be the ideal setup.
    I'm sure others will chime in.
    If the pump is fine, I'd just replace the motor (2-speed) also a new shaft seal.
    Citizen's Avatar
    Oct 2014
    Orlando, FL
    92
    Hey Auburn, do you have any model or part numbers from your motor or pump so we can see what you are working with? A picture of the label would do nicely.
    FlyAU98's Avatar
    Jul 2014
    59
    The motor stopped working sometime yesterday afternoon or this morning. So its replacement time one way or the other.
    Pictures of the set up are below. The solar panels are on a one-story, gradually sloped roof.
    Like I said, I don't have any hangup replacing it with a single speed motor/pump, but if there is some reasonable savings to be made without significant installation costs, I don't mind the extra $$$ for a two-speed or variable speed pump.
    At this point, not knowing the age of the existing pump (it looks like its been there for a while), I'm inclined to replace the entire thing, pump and motor.
    I'm looking for advice....
    Apr 2011
    Murrieta, CA
    2,360
    Re: Pump motor DIED, what to replace it with? (Solar)
    Looks like a dura glass pump. They're pretty durable. No need to swap out the pump. You can take off the silver band and remove the mounting plate/motor assembly with out having to do any thing with the plumbing.
    http://www.pentairpool.com/pdfs/DuraGlasOM.pdf
    How many hour a day is the pump running? How long is the solar on? You could get a two-speed motor and wire it with a high/low switch, keep in on high speed, use low when the solar isn't working. I'm sure there's a relay you could install to switch from high to low. But don't have any info currently. I'm sure it's been done in the past.
    FlyAU98's Avatar
    Jul 2014
    59
    That looks like the right manual. The pump runs about 5 hours a day, I try and keep the time adjusted so that its running when the sun is best for the solar (we like the pool warm). I'm not sure that manually going from low to high for solar would be very useful to us.
    That said, I'm not entirely sure when the solar is on or off. I leave the solar controller set just below 90 and ignore it. I assume that has the solar running full time, except perhaps in the summer.
    I think my only interest in a variable/2 speed pump would be if somehow my existing solar controller would clue it in to run fast or not.
    Apr 2011
    Murrieta, CA
    2,360
    Sounds like you may be best off just keeping the single speed motor. Just replace what you have. There are some good deals on rebuilds.
    FlyAU98's Avatar
    Jul 2014
    59
    Quote Originally Posted by bobodaclown View Post
    Where?
    FlyAU98's Avatar
    Jul 2014
    59
    I removed the motor as you suggested. It came off fairly easily, other than the nut that secures the silver band was pretty well rusted...it was tough to back off.
    Here is what I have now:
    Any thoughts on the pump section? Its a bit discolored...is it still worth reusing? If I go all DIY on this, I assume I need an o-ring kit?
    I'm thinking about just having my wife take what I removed to the 'old school' pool shop nearby and seeing if they have the motor/seal kit to fix it, so I can try to pop it back on tomorrow night...
    May 2008
    Northern California
    71
    Up here in Northern California, I turn off the solar during the winter and run on low speed which saves quite a bit of cash, but being that you get a lot more sun and run your solar year-round, a single speed motor would probably be okay. Your pump's wet end looks okay to me and if you replace just the motor, you avoid having to do any PVC work. You would need the two o-rings (and lube) and a new shaft seal. Sounds like you're a DIY'er, so you should have no problems replacing the motor. I just followed the instructions in the manual and got it done.
    [EDIT] Replacement parts are readily available, so if you want to, say, replace the band clamp and a new shiny one, just order one.
    12,000 gal. IG Colorquartz, 1.65hp Sta-Rite with 2-spd motor, 300sf cartridge, disabled SWG, AquaLogic P4, Polaris 280, gas+solar, 6' sheer descent with dedicated pump
    FlyAU98's Avatar
    Jul 2014
    59
    Quote Originally Posted by bignick View Post
    I definitely run the solar all winter. With a few exceptions when we had a stretch of cloudy days, the pool has been at least 81 degrees on days I've wanted to use it for the past couple months!
    Apr 2011
    Murrieta, CA
    2,360
    FlyAU98's Avatar
    Jul 2014
    59
    My local, non-chain pool store replaced the motor and seals for me...he did the work in the shop for the same price the motor itself (without the seal kit) was going to cost me online.
    But of course, the rusty clamp band that holds the pump together won't tighten up now (from the threads being damaged when I removed the nut) so the pump is leaking.
    New clamp on order...
    And of course, the plastic nut that connects the chlorine feeder (that I don't use) completely disintegrated when I touched it, so now I have to figure out how to fix that too.
    FlyAU98's Avatar
    Jul 2014
    59
    So...1 year and 12 days later...the pump/motor is getting a little noisy again...
    I would suspect the 'quality' Chinese replacement motor.
    All that has changed since my original post is that the intermatic timer has been replaced with a intermatic combo transformer/mechanical timer...and everything has been rewired fresh.
    So I intend to continue using the Intermatic timer for on/off. Solar is still running most all the time, so I suspect I stay with single speed.
    Where do I get a motor that lasts for more than a year?
    I'm going to swing by the old school pool store that swapped the motor for me last year and see how close we are with the 1-year warranty...
    Apr 2011
    Murrieta, CA
    2,360
    Replace the bearings yourself. It's pretty easy.
