Results 1 to 8 of 8
Thread: Paver decking dilemma
    Dec 2014
    Frisco/Texas
    45
    Are deck, 400 sq ft, will be pavers. Just wondering if anyone has any recommendations on the type we should go with for our pool. We have a red brick patio that will touch up to the deck,our coping is Oklahoma flagstone, the spa will have off white flagstone brick.I am needing some help with:
    1) do we go with larger pavers to make the deck appear larger or go with smaller pavers as the area is only 400'
    2) do you try to match the brick color and contrast the coping and spa or do you contrast the brick and use a paver that blends with the coping and spa
    Oct 2014
    Kingwood, TX
    100
    Re: Paver decking dilemma
    I would try to make the flagstone and paver deck blend together. You dont want to introduce more colors. Pick a color paver that matches the flagstone but blends with the red brick.
    Or you can always save up and replace the red brick at a later day.
    We have a grey herringbone pattern paver patio and OK flagstone. We chose a almond / Walnut stamped concrete pattern.
    Dec 2012
    Frisco, TX
    40
    Check out Belgard Mega-Arbel pavers. They are pavers but look like flagstone. Custom Stone Supply in Frisco off of John Elliot Dr has some installed onsite so you can see what it looks like
    22K Gal, Chlorine, IG, Pebble Sheen Plaster, Jandy 60Sq Ft DE Filter, Intelliflo 3HP VS pump with SVRS, Rainbow 320 Chlorine Dispenser
    Other Equip - Jandy PDA PS6, Jandy LRZ400 Heater, Polaris 280 vacuum
    Features - Spa with fountain that empties into pool over waterfall spillway and separate table rock waterfall, Pool gets full sun until later afternoon and then partial sun
    Pool completed and filled 6/28/13
    Dec 2014
    Frisco/Texas
    45
    If anyone has any pictures of a pool with paver decking, I'd love to see them. We now have our coping and are trying to decide what type and color of pavers to use.
    Here is a picture of the pool with the coping. The deck will be on the left side of this picture from behind the spa to about where I was standing while taking the picture. It will touch up against the red brick on the back patio.
    Dec 2012
    Frisco, TX
    40
    Here is the Mega Arbel installed. Not sure if it had been color enhanced and sealed yet in that picture. We also have Oklahoma flagstone coping.
    Oct 2014
    Kingwood, TX
    100
    I can take you some more pictures this weekend if you want. We have cleaned and scrubbed since this picture....oh and we have plaster and water. I will be updating my thread soon.
    We have the Standard Grey Holland Paver - Herringbone Pattern, Almond and Walnut Travertine Stamped Concrete and Oklahoma Flagstone.
    Dec 2014
    Frisco/Texas
    45
    That's a good view. Thanks!
    Dec 2014
    Frisco/Texas
    45
    I wasn't overly impressed with any of the choices for pavers, so I put the decision on the wife (just in case we don't like it). We went with the Belgard, Dublin Cobble, in Harvest Blend:
    http://www.belgard.com/products/pavers/dublin_cobble
