Results 1 to 13 of 13
Thread: Flowvis Flow Meter
    whataboy's Avatar
    Jan 2015
    Lewisville,Texas
    53
    Flowvis Flow Meter
    Should the Flow-vis flow meter be installed on inlet or outlet side of my pump filter? I have no room on inlet side so hopefully it will function properly on the outlet side of filter. Thx
    30,431
    Re: Flowvis Flow Meter
    Yes, it will do fine on either side.
    mas985's Avatar
    Pleasanton, CA
    11,741
    I think the outlet side of the filter is a better position so debris does not get in the way of the check valve closing and not sealing properly.
    Mark
    whataboy's Avatar
    Jan 2015
    Lewisville,Texas
    53
    Thanks for the input. Just installed a Pentair VS pump and will install Flow-vis flow meter soon to see how many gpm's I get at different rpm's which will determine run time to turn over my 15k gal. pool.
    whataboy's Avatar
    Jan 2015
    Lewisville,Texas
    53
    Cool site, glad I found it
    Rick T.
    12,000 gallon IG Kidney shape,gunite,white plaster w/25% blue quartz (Chlorine)
    Jandy LED Multi-color pool light, ,Pentair VS Pump,Pentair FNS 48 DE Filter,Polaris 280 Cleaner
    TF-100 test kit, Taylor K-2006 test kit, Speed Stir, BBB Method, PoolMath, TFPC
    mas985's Avatar
    Pleasanton, CA
    11,741
    Quote Originally Posted by whataboy View Post
    The concept of turnover is a little outdated. Flow rate has little to do with required run time. Read the study in my signature and the pool school article here:
    http://www.troublefreepool.com/conte...-pump-run-time
    Mark
    whataboy's Avatar
    Jan 2015
    Lewisville,Texas
    53
    Does anyone know where I can purchase a Flow-vis Flow Meter in the Dallas,Texas area? Thanks..
    Rick T.
    mas985's Avatar
    Pleasanton, CA
    11,741
    You can get one from Dave: http://tftestkits.net/Flow-Meters-and-PSI-Gauges-c12/
    But again, flow rate is not all that important to know.
    Mark
    Sep 2016
    Arkansas
    437
    Installed a Flow-vis check valve today after my heat pump. Had to remove and replace the 8 screws and apply silicone grease to the o-ring 3-4 times before I was able to get a good seal without any leaks at higher pump RPMs.
    Approx how accurate is the Flow-vis reported GPM?
    17'x35' 22,500 gal. Gunite IGP 3.5-8.0 ft. IC60 SWG, 2 skimmers, 2 main drains, 4 returns. CCP520 cartridge filter, 3hp IntelliFlo 2 VST VSP, EasyTouch 4, ScreenLogic2, 2 IntelliBrite Color LEDs, Poolmiser autofill, UltraTemp 120R H/C 125K BTU heat pump, Diamond Brite Super Blue, No spa or water features.
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    7,541
    Miles,
    You might want to check out the meaning of OCD...
    Sep 2016
    Arkansas
    437
    Quote Originally Posted by Jimrahbe View Post
    Miles,
    LOL. All kidding aside, my PB installed a Jandy check valve after my heat pump. I replaced the valve with a Flowvis retrofit kit. However I couldn't seem to get a tight seal in on one particular side of the valve lid no matter how hard I tightened the screws. So I finally removed it again and liberally applied the silicone grease and tightened again, starting with the side that was leaking. This time it seemed to make a good seal. Yes, it was making me crazy!
    mas985's Avatar
    Pleasanton, CA
    11,741
    http://www.h2flow.net/flowvis-flow-meter/
    Average accuracy:
    97.9% between 10 - 90 GPM (1.5" model)
    97.9% between 10 - 110 GPM (2" & 2.5" model)
    98.15% between 90 - 220 GPM (3" model)
    98.7% between 160 - 300 GPM (4" model)
    Mark
    needsajet's Avatar
    Jan 2016
    Sydney, NSW, Australia
    4,278
    A good reason to have it on the return side is to let it double as a check valve, just before chlorine injection or an SWG. I can swap mine with the check valve on my solar heat and do calculations on heat output, but yep it's mostly a human interest kinda device. If you have a buddy with a Jandy check valve you can share it. I like having it with the VS pump. Friction loss is a cost, albeit minor, unless it's doubling as a needed check valve. If it isn't needed after you know the system, you can remove it and replace with a cover with no check valve in it.
    I might get poked with a stick for OCD, but I tighten them in a star pattern, going around twice, like a truck wheel.
    Glad you found TFP
    12k IG salt; glass beads in plaster; K-2006C, K-1766, CCL, and Aussie 4in1 (HTH); Pentair Eco800 1.2HP VS; Zodiac SWC 1.3 lb/day (25 g/hr); 25" filter recycled glass; OKU solar panels; 1/2 HP solar pump; Rebel (Warrior) pool cleaner; FlowViz; prior pool AG 10k | Read Before Posting to get the best possible advice | ... and this helped me a lot!: TFPC for Beginners
