Thread: HELP! Building Pool next to Pecan Tree - Paramount PCC 2000
    A friend is building a pool next to a pecan tree and one builder has told him the "self cleaning" Paramount PCC 2000 can handle the pecans in the pool. Another builder told him that he didn't think it would be able to handle it. This is obviously a big upgrade and he was curious if anyone had any experience or thoughts on this.
    All comments are greatly appreciated, thanks for your experience and help!
    15x32 16k Gal IG riversand (pebblesheen) pool, Filter: Jandy 48 sq ft DE filter, Circulation Pump: Stealth Pump 2 hp 2 speed, SWCG, Heater Size and Electronic Ignition: Jandy LRZ400 Natural Heater, Cleaning System: Polaris 280, Spa: 8 Jets, 1 fountain, Polaris 220V 1.5HP QT blower
    Pool Tool's Avatar
    May 2014
    Western Chicago Area, IL
    757
    Re: HELP! Building Pool next to Pecan Tree - Paramount PCC 2000
    A pool next to a pecan tree...that's nuts! Sorry couldn't restrain myself.
    No particular experience with a paramount, seems robust. Although it is still moving debris through the piping to the canister. I would be hesitant to funnel pecans, or any large roundish objects, to any buried piping. From experience, I know that just a few acorns can jam up a vacuum hose rather quickly. Not exactly the same scenario, but similar.
    16' x 32' (21100 gal), vinyl, 1.5 hp Hayward SuperPump,
    Tagelus TA60/60D Sand Filter, Raypak 399K Digital Heater, TF-100
    JayBauman's Avatar
    Sep 2014
    Katy, TX
    617
    I have the Paramount PCC2000 IFC system in my pool. I can't speak about nuts, but the nozzles really do put out some pressure and I would imagine that the system could push them towards the main drain without any problems. Your friend needs to work with the pool builder to make sure that the MDX floor drain has large enough openings to be able to suck up the nuts. If the nuts pass through, then go for it. If they don't fit through, then you'll always be manually cleaning them off the floor.
    My recommendation is to go for it anyway. The system really works and is really zero-effort. So the nuts might not fit, but it's good for everything else.
    23' x 37' IG 18.5k gallon SWG w/ raised spa, Build Thread -->Here
    Wet Edge® Pearl Matrix®, Hayward® SwimClear™ 525 ft², Hayward® Goldline Controls® PS-8
    4x Hayward® TriStar™ pumps, Paramount PCC2000® ICS, TF-100 w/Speedstir
    MARCO...polo's Avatar
    Oct 2014
    East Contra Costa County CA
    102
    I've found a few small acorns (medium jalapeno size) in the pool and in my PV3 debris bag. Interestingly the closest oak tree is at least a half mile away. As a random occasional thing I'm okay with this but I doubt I would deliberately tempt fate knowing that nuttage [snic] is a continual problem.
    13,000 gal.Peanut shaped IG Plaster (med. gray) w/ 7' raised spa. ALL Pentair: Intelliflow 3hp VS, Cartridge filter, 400,000 btu heater, 2.0hp spa motor, Easy Touch control panel & is4 spa side switch, Intellichlor 40C SWG, Paramount PV3 In Floor cleaning system, spa spillway and two sheer descents. Solar: 10 FAFCO panels 1.5hp booster. Testt kits: K-2006 & K1766 (Chloride/Salt) Fill date August 15, 2114.
    SW Georgia
    300
    Fortunately my pecan trees are not close enough for the pecans to get in my pool but I do get the 8 to 10 sticks that shed off of the tree yearly that cause me problems. These sticks weigh less than the pecans and the wind carries them into the pool.
    35K IG Vinyl 20 x 40 self built pool, Hayward Pro Series High-Rate Sand Filter 31" 98gal/min, Hayward TriStar 1.85hp, Hayward 400btu heater, BBB method w/Hypo, Jazz light w/matching fiber optic rope lighting around coping w/syncronized color wheels. Concrete Paver deck.
