Thread: Is it possible to pressure test a pool's plumbing with disconnected equipment
    May 2013
    Miami, FL
    23
    Is it possible to pressure test a pool's plumbing with disconnected equipment and an empty pool?
    I'm finally redoing the pool of my new house and realized it's not going to make much sense to test the lines after all the deck and pool work are finished. If it doesn't work right we have to tear up that work!
    pool owner since 2012
    13-15k gallons, kidney shaped,in-ground plaster
    1970s construction, currently undergoing complete renovation
    3 jets, 1 skimmer, 1 dedicated vacuum line, kreepy krauly great white, main drain
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Re: Is it possible to pressure test a pool's plumbing with disconnected equipment
    Anything's possible. May have to get creative though. Use fittings, plugs, a pressure gauge, and a soap bottle to test the plugs.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
