Thread: Inground Salt Water System
    Jan 2015
    hampstead NC
    1
    I have a 20,000 gallon in ground pool and want to install a salt water system. What's the most efficient/economical brand and model recommended?
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Re: Inground Salt Water System
    Efficiency should all be about the same. You basically have a transformer blasting lower voltage DC current across titanium plates. Shouldn't be much noticeable difference between the units. Hayward, Pentair, Autopilot, and Compupool are the names that come to mind. There are others I can't remember at the moment. Depending on the model you choose out of those brands you are looking at $800-1400. If you are looking for economy for that size pool, I'd say you will probably lean toward the Hayward or Compupool. Make sure you get one that's rated for 2-3X the size of your pool so you don't have to run your pump 24/7 to make enough chlorine.. Those two have relatively inexpensive cells vs say the Pentair that is 75-80% of the price of the whole system.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
    Citizen's Avatar
    Oct 2014
    Orlando, FL
    92
    Quote Originally Posted by n240sxguy View Post
    I would stay away from Compupool, just from past experience they are a nightmare to deal with. Parts are always on backorder; because the product is made in Australia, the lead times are ridiculous and longer than expected.
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Quote Originally Posted by Citizen View Post
    It's because of those issues that they are not 1st on my list personally.
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    I've gotten one of the CPX series to replace a CPSC unit. So far so good.
