Thread: Quietest Hayward VS pump?
    Oct 2014
    Austin/TX
    27
    Which VS pump from Hayward makes less noise - the Eco-Star SVRS pump or Tri-Star VS?
    mas985's Avatar
    Pleasanton, CA
    11,741
    Re: Quietest Hayward VS pump?
    The major contributor to noise (on a new pump) is the flow rate. The higher the flow rate, the more noise there is. So at the same flow rates, both pumps should be equally quite. Plus both use the same wet end so no different there.
    Also, what makes old pumps noise is mostly worn bearings in the motor not the pump design.
    Mark
    By the by, I would avoid getting an SVRS pump unless you are required to have one. In some situations that is a crucial safety feature, but if safety is insured in other ways, having an SVRS pump in addition has a habit of causing problems.
