Results 1 to 9 of 9
Thread: Hayward H350FDP heat will not fire up
    Jan 2015
    melbourne, fl
    5
    I have a Hayward H350FDP propane heater for my spa that is about 7 years old. It turned the unit on this weekend which is run at least a couple times a month and I could hear the blowing blowing but the heat and gas would not kick on. What kind of things can I trouble shoot to see what the problem might be? The only error code on the screen was b0 which I think it just something to do with a bypass to use the remote. Thanks
    Jan 2015
    melbourne, fl
    5
    Re: Hayward H350FDP heat will not fire up
    Quote Originally Posted by adamra1 View Post
    What kind of trouble shooting step can I take?
    ps0303's Avatar
    Jul 2011
    FL
    3,684
    Yes the bo is for bypass operation. Are there no error codes on the display? I'm guess this is propane, FD"P", so are you sure you have propane?
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Jan 2015
    melbourne, fl
    5
    Quote Originally Posted by ps0303 View Post
    Yes definitely have propane. No other error codes on the display aside from b0. The blower is blowing air out of the exhaust on top of the heater but the propane is not igniting.
    ps0303's Avatar
    Jul 2011
    FL
    3,684
    Do you hear the ignitor clicking, smell propane?
    Paul
    Jan 2015
    melbourne, fl
    5
    No it is not clicking and I am not smelling any propane
    ps0303's Avatar
    Jul 2011
    FL
    3,684
    First thing is I would make sure you are actually getting gas out of the regulator by the heater. It hopefully has a drip leg that you could removed the cap and then turn the valve on to see if it's flowing. If it is, then I would suspect the ignitor since you don't hear the typical sparking sound they make.
    Paul
    Jan 2015
    melbourne, fl
    5
    Ha, just realized the guy from Suburban Propane turned off my gas supply to the spa heater last time he was out!!! Sometimes the most simple solution is the answer. Thanks for the help
    ps0303's Avatar
    Jul 2011
    FL
    3,684
    Glad you found the issue.
    Paul
