Results 1 to 7 of 7
Thread: Adding a SPDT HI/LO Toggle Switch
    Dec 2013
    Folsom, CA
    11
    Hi,
    Is there a way to add a HI/LO toggle switch directly onto a B2982 dual speed pump motor?
    http://www.lockewell.com/index.php?m...oducts_id=2245
    I'm running the pool equipment through an Aqualink RS4 but need to switch the pump speed manually.
    Thanks.
    Inground pool and spa - 16,000 gallons
    PebbleTec, SWG, Solar, Waterfall Sta-rite Max-E-Pro 1.5hp
    Separate pumps for solar and spa, Aqualink RS4 controller
    Cartridge Filter, The Pool Cleaner (suction)
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Re: Adding a SPDT HI/LO Toggle Switch
    Dec 2013
    Folsom, CA
    11
    Thanks Bob. So I should be able to drill a hole the the back cover? Then hook up the correct wires to the switch (once I find them)? is it that easy?
    It is very easy, you just need to make sure there is enough room behind where ever you drill the hole the switch mounts in.
    Apr 2011
    Murrieta, CA
    2,360
    Yes, the box comes with a knockout, and I ordered the switch from digikey. '
    Here's a couple other solutions if you wanted to use a wall type switch:
    http://www.troublefreepool.com/threa...iring-Question
    http://www.justanswer.com/electrical...oggle-swi.html
    Dec 2013
    Folsom, CA
    11
    I think I have the wiring down. I just want to make sure I get the right switch.
    So, will this switch work? http://www.digikey.com/product-detai...054-ND/1835155
    or do I need a switch rated for 250v?
    Something like this one is probably more appropriate.
    It needs to be rated for 250 volts if your pump is 230 volts, can be rated 125 or 250 volts if your pump is 115 volts.
