Results 1 to 11 of 11
Thread: Pump housing model #
    Jan 2015
    South Lake Tahoe, California
    11
    Greetings, Just got here. Got a cracked Hayward pump housing {freeze damage}. Can't read the model # anymore. Can I somehow tell so I can get another one? pump1.JPGpump2.JPG
    Let's see if I can post pictures. Thanks.
    Richard
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: Pump housing model #
    It is a power-flo pump and you can get the size from the motor label but I can't see it very well. Let me know the label HP and service factor and I can tell you the model number.
    Mark
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Here's a link to the manual with part numbers: https://www.hayward-pool.com/pdf/man...-SP1575X15.pdf
    Hope it helps.
    Jan 2015
    11
    Hi Mark, Yes, it's a Power-Flo Model # S48 2A2 I think the letter after the 8 is an N not sure.
    HP 3/4
    Ser 8L94
    Duty Cont code K
    SP-1510-Z-E
    Thermally protected CET 36AEM
    Thanks for coming by
    Richard
    mas985's Avatar
    Pleasanton, CA
    11,737
    SP-1510-Z-E is the model #. There were/are several versions of the PowerFlo and you have one of the earliest versions. A quick search popped up this site:
    http://www.ereplacementparts.com/hay...76_146874.html
    Mark
    Jan 2015
    11
    Mark, Thanks, I'll see what I can do with that.
    Richard
    If the pump is old, you would probably be better off getting a new one.
    Support the site
    Jan 2015
    11
    I just put bearings and seal in the motor. If I can't fix this housing or find one I'll rework one I have here. There's a MAX-FLO here I'll have a look at that, I've been wanting to go through it, to have a spare.
    First I'll see if I can patch or find a part for this one, I would like to get some service from it, having just gone through the motor.
    Richard
    Apr 2011
    Murrieta, CA
    2,360
    Hi Richard,
    Looks like you can get a housing pretty inexpensively. ($30)
    http://www.bonanza.com/listings/Spx1...VgIRoC6v3w_wcB
    Jan 2015
    11
    Greetings bobo, That isn't the right housing, but thanks. What is this Bonanza maybe I can get the correct on there?
    In the mean time I did a patch, with a soldering iron and a clamp.
    We need the Hot Tub, we're in it every night. Wifey skis for pay, when she comes home, after feeding the animals, the tub is the place to be.
    Jan 2015
    11
    For some reason I was only able to upload one photo of the repair.
    I'm filling the tub now, when I kick the tub on it doesn't seem to leak.
    Richard
