Results 1 to 7 of 7
Thread: is there such a thing?
    Jun 2014
    Houston, Texas
    479
    we have a Shark and while it does a good job of cleaning, it doesn't get everything. is there a hand operated cleaner that you can use to manually get what you want - kind of like a vacuum cleaner, I guess???
    19k SW IG
    Wet Edge pebble tech = new 5/16 (replaster)
    Hayward variable speed pump (new 6/17) /Shark for cleaning
    New - filled 10/18/14 - TFP 100 test kit
    Re: is there such a thing?
    Water Tech makes a whole lineup of hand held cleaners such as you describe.
    Jun 2014
    Houston, Texas
    479
    cool. i will check them out. thanks!
    19k SW IG
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,075
    http://watertechcorp.com/products-catfish.htm I have one. Works okay. Not good for the whole pool, but it will grab the odds and ends that fall in immediately after you put away the hose.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,659
    I highly recommend the Pool blaster line.
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,778
    I have a max blaster that is fab for spot cleaning...but admit. Hardly use it anymore now that I ave the dolphin mx4 supreme...which doesn't miss spots
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
    Jan 2013
    Long Island, NY
    184
    Quote Originally Posted by DMS2014 View Post
    Why not just connect your skimmer pole to the shark and move it around manually to pick up the debris it doesn't get on it's own?
    Doughboy 12' x 20' Saphire semi-AG, Installed 2012
    Waterway 1.5 HP 2 speed, 100 sqft cartridge filter
    Aprox 7000 Gal, Full sun, 85K heat pump,
    TF-100 test kit
