Thread: Cant understand 3rd automated valve on pool setup
    Oct 2014
    Heartland
    14
    Hi all-
    So this community has already helped me out in my 4 short months of being a pool owner so I wanted to give another question a shot. My pool has 3 automated valves in the piping set up. 2 are before the pump and switch when placed in pool or spa mode and I understand them completely. The 3rd is directly on the outlet of the pump and is in between my cartridge filter and heater for either the spa or pool and the other goes to a Polaris cleaner in the pool. So there are only 2 outputs on the valve so I am just confused what the point was of putting the automated valve in this spot. I basically can either have the pool sweeper on or run water through my filter....makes no sense. I take the valve to the middle position and just turn the toggle switch off. If someone can understand why this valve makes since please let me know. I am planning a re-plumbing project this spring and if the valve has no use I would rather just put a manual 3 way valve in its place.
    Oct 2014
    Sacramento, CA
    72
    Re: Cant understand 3rd automated valve on pool setup
    Looks like it can control the flow of your pool cleaner its probably on a schedule so that when the pool cleaner isn't running its not always restricting the water actually thats exactly what it is now that i look at it again.
    David Randolph
    Warranty Station
    Pentair
    Jandy
    Owner Sac Pool Pros
    Qwaxalot's Avatar
    Jun 2012
    439
    It's there to turn off the pool cleaner when in spa mode. Otherwise the spa would empty into the pool.
    In the industry, CSP (Certified Service Professional) by the NSPI and it's successor the APSP. My company services over 600 pools every year. I think the practices regularly espoused on this forum (especially the BBB method) are outstanding; however my comments will be often oriented towards the goal of getting it done, and getting it done right now!
