Results 1 to 12 of 12
Thread: Pop-up Cleaner
    Jan 2015
    Las Vegas
    9
    Pop-up Cleaner
    I bought a home with a pool that was inoperable; so I had it replastered and bought all new equipment. The pool is now up and running, and is fantastic! However, one of the few remaining items for me to figure out has to do with an apparent pop-up cleaner that I have on the landing of my pool.
    When the pool was re-plastered, the put an eyeball in where the pop-up cleaner goes Needless to say, I figured that wasn't the right "fitting" for that hole. I've been told that what I need to put there is a pop-up cleaner that cleans off the big step landing in the pool. That being said - I can't figure out how a pop-up cleaner works. I've never been able to feel any water coming out of there; when the pump is on, and returning to the pool, or when the cleaner is on (I run a sideport cleaner). Is this normal? How do the pop-up cleaners work?
    Thanks!
    14,000 Gallon In-Ground Quartz Plaster
    Cartridge Filter, Pentair Intelliflo VS Pump with 420 SqFt Pentair Clean and Clear Cartridge Filter
    Pentair MasterTemp Heater with Zodiac Blower for Spa, Poolverneugen Automatic Cleaner
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Re: Pop-up Cleaner
    By any chance is it an umbrella holder? Can you post a picture of the fitting, and can you post a picture of your plumbing setup?
    Jan 2015
    Las Vegas
    9
    Re: Pop-up Cleaner
    Sorry for taking so long to respond; but here's a picture of my pump/filter/heater setup, and a picture of the hole where I'm assuming the pop-up cleaner goes. Notice that there's an eyeball in there . . . I haven't bothered taking it out yet.
    Here are the pics
    38,284
    Re: Pop-up Cleaner
    There are no pictures.
    Try to follow the How To Post Pictures tutorial.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Pop-up Cleaner
    Still not showing up
    Jan 2015
    Las Vegas
    9
    Re: Pop-up Cleaner
    There we go - now they're posted. My apologies!!
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    Re: Pop-up Cleaner
    My bet is that bobo got it right. That looks like an umbrella sleeve. Pull the fitting out and probe around. I think you will find that it's just a sleeve with no plumbing to it.
    chiefwej
    PoolESQ's Avatar
    Dec 2007
    Albuquerque, NM
    191
    Re: Pop-up Cleaner
    Given it's location, that there is only one, and I see no evidence of a head unit in your pic, I'm 100% sure you've got yourself an umbrella sleeve.
    Replastered 2015: Sunstone Quartz Midnight Blue 16x32 rectangular gunite with in-pool spa....18,000 gallons. Autopilot Total Control System with SWG and acid pump. Pentair Clean & Clear 420. Auto cover. TF-100.
    38,284
    Re: Pop-up Cleaner
    I am not sure I would go 100% that it is an umbrella sleeve ... maybe 95%. It is possible it could be a bubbler jet in that location as well.
    What does that small pipe with the closed ball valve do that is in front of the filter? That could be for a bubbler, or it could be a bypass to feed a little water to the spa to keep it chlorinated.
    PoolESQ's Avatar
    Dec 2007
    Albuquerque, NM
    191
    Re: Pop-up Cleaner
    A bubbler jet. Of course it could be. *Newman!*
    Jan 2015
    Las Vegas
    9
    Re: Pop-up Cleaner
    The small pipe with the ball valve coming off of the return line runs to an in-deck chlorinator.
    No water has ever come out of that "hole" on the landing . . . BUT, I have never checked it when I have the chlorinator turned on . . . I'll make sure to do that. Otherwise, I'll take the fitting out and feel around.
    Thanks everyone!
    Apr 2011
    Murrieta, CA
    2,360
    Re: Pop-up Cleaner
    A bubbler, or small fountain would be cool. Keep us updated. Can you take a closer/overhead picture of the fitting? I'm still leaning towards an umbrella holder.
