Thread: Main Drain Question
    Jan 2015
    Las Vegas
    9
    Main Drain Question
    Hello All! I'm new a new pool owner, and a new member of the forum. I'm excited to be a part of the community!
    I've done a pretty decent job learning how my pool works, how to treat the water, and basic maintenance, etc. However I am curious as to how my main drain is connected to my pump.
    Of course, in the skimmer, there are two holes at the bottom. One of them is directly pulling water from the surface of the pool; but the other hole appears to be leading to the main drains at the bottom of the pool. Is this a normal configuration? It would seem to me that the main drain should need to be directly hooked into the suction line, rather than feeding into the skimmer like it is. I have a sideport automatic suction cleaner that I run when needed; but it's just unnerving to me that the drains at the bottom of the pool aren't directly hooked into the suction from the pump.
    Is this configuration the norm?
    Re: Main Drain Question
    Welcome to TFP!
    The setup you describe is common enough, though it is far from idea.
    There is a special fitting that you can get that goes in the skimmer which allows you to force some of the pump suction to draw from the main drain.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    Welcome!
    Yes, your configuration is normal. What you're missing is a diverter. Here's a couple pictures of what they could look like:
    The spaceship one has a float inside, so if the water in the skimmer gets too low, it blocks the openings to the skimmer and draws only from the drain. Otherwise, there's a flap underneath that you move to regulate the flow from full skimmer to full drain or somewhere in between. I find it useful to have some suction through the main drain because it eliminates a lot of the temperature stratification.
    Look around and see if there isn't something like that floating around in the shed left behind by the previous owner. Or measure your skimmer well and go visit a pool store and see if they have a universal one that will fit.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Welcome to the forum!
    Hope you enjoy your time here. You've goten some good answers so I can add much. Enjoy your time on TFP!
    Essential Links:
    Jan 2015
    Las Vegas
    9
    Great! Thanks for the responses. Yes - I will definitely purchase a diverter. Thank you for your help!
    14,000 Gallon In-Ground Quartz Plaster
    Cartridge Filter, Pentair Intelliflo VS Pump with 420 SqFt Pentair Clean and Clear Cartridge Filter
    Pentair MasterTemp Heater with Zodiac Blower for Spa, Poolverneugen Automatic Cleaner
