Thread: Air Bubbles In Return To Pool
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    Question Air Bubbles In Return To Pool
    Hello TFPer's....
    Just a quick question... I've recently upgraded all the plumbing, fittings, and cartridge filter, on my above ground pool, but I've got air in my return.... I can see it in the water, I can hear it, and when the solar cover is on it creates a bubble underneath it....
    The intake and returns are all good, so I'm thinking maybe the filter or the pump is where I've got the leak???
    Thanks in advance
    Intex Rectangle 18 x 9 x 52', 4544 gallon (18000 litres), 0.75 hp pool pump, 100 sqft Zodiac Titan Cartridge Filter - 40mm, Stenner Peristaltic Pump chlorine injection system, Intex Over The Wall Skimmer, Intex Fittings with 40mm plumbing Lil Patch Of Heaven. Build/Construction http://www.troublefreepool.com/threa...lice-of-heaven
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Air Bubbles In Return To Pool
    Somewhere on the suction side. Check your pump lid first and work upstream from there. Air is getting in somehow...
    Essential Links:
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    Thanks Brushpup...
    Oct 2014
    Sacramento, CA
    72
    Any 2 way or 3 way valves in front of pump real common for those after years of aging to suck air could just need some new o rings
    David Randolph
    Warranty Station
    Pentair
    Jandy
    Owner Sac Pool Pros
    Oct 2014
    Bay Area, California
    146
    Use a garden hose on various areas of the suction side
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    All my stuff is brand spanking new, hoses, cartridge and pump, I think I've located the leaks... The cartridge filter seems to be the perpetrator... Thanks again guys....
