Okay. I added 96oz of Calcium Hardness Increaser (from Pinch-A-Penny...looks like Calcium Chloride from the MSDS) which brought the CH up 30 to 80 (broadcast into the deep end with the pump on high and main drain sucking). I added another 32oz just now. I know this isn't near enough, but from your recommendation, I am adding in small amounts so I don't overshoot and I've been reading it may take a little while for it to register/combine completely. I have another 8 lbs bag of it waiting in the garage when I check it in a few days. Out of complete curiosity, I took a water sample to a Pinch-A-Penny (different than previous pool stores) and their measurements were pretty accurate, except CH, which they said I was at 95. Going to trust my results more on this one.
I added 24oz of stabilizer via the sock in the skimmer method. Still nothing registering for that, so I added another 24oz just now. According to pool math, this should put me in the lower range of 30 which is the lower range of the recommended levels. A
ny idea how long before I should test? I am down to a half bottle of the CYA solution due to all the testing I have been doing and I feel this could wait a week to test as long as FC stays in check.
Do you agree?
Current readings:
FC: 6
CC: 0
pH: 7.2
TA: 130
CH: 80
CYA: 0
Water Temp: 67
CSI: -0.71 (up 0.16 from last night's test)
Looks like I am getting back in business.
Any ideas on the fibrous packing I found in the skimmer? I have an enclosed pool, so I'm not sure if it's material left from the crew who acid washed and refilled, or something else that I should be concerned about. It's about the same diameter as my LED lights and return jets...
