Jet pump stopped wokring
Apr 18, 2014
18
Canada
Hi,
I have a Pacific Hot tub with Balboa panel and Aber top side panel. Today the jet pump stopped working as I may have overfilled yesterday. I add some water to raise the level and forgot all about it.. Today the jet pumps don't turn on if in filtration cycle or by pushing the button on the top side panel. There is voltage in the main panel as I have checked. Glass fuse looks good and other fuse has confirmed continuity. When I reset the breaker I cannot hear the relays switching which I have always been able to hear before. The jet pump was running in filtration cycle when I over filled it. Is the this a result of a shorted topside panel?
