Thread: Jet pump stopped wokring
    Apr 2014
    Canada
    18
    Hi,
    I have a Pacific Hot tub with Balboa panel and Aber top side panel. Today the jet pump stopped working as I may have overfilled yesterday. I add some water to raise the level and forgot all about it.. Today the jet pumps don't turn on if in filtration cycle or by pushing the button on the top side panel. There is voltage in the main panel as I have checked. Glass fuse looks good and other fuse has confirmed continuity. When I reset the breaker I cannot hear the relays switching which I have always been able to hear before. The jet pump was running in filtration cycle when I over filled it. Is the this a result of a shorted topside panel?
    Re: Jet pump stopped wokring
    I would suspect a stuck relay, though it could be any of several things. Do you feel comfortable checking some voltages with a multi-meter? If so you could narrow it down fairly quickly.
    Apr 2014
    Canada
    18
    Very comfortable working with a multimeter. Could I just spray electrical cleaner on the relay? I have some and some other cleaners on hand.
