SoCal Rock Pool
bdavis466
Platinum Supporter
Aug 4, 2014
5,616
San Clemente, CA
I have enjoyed looking at everyones pools, so I figured I should take the time to post mine. Here is the basic design I came up with...I am fortunate to be able to do my own plans and a majority of the work. I plan to do as much as possible myself.
Plumbing going in. I went with 3" lines in a looped return system for the pool. I thought long and hard about the infloor system but chose not to based on mixed reviews. I'm hoping I don't regret it.
Dug the footings for the fireplace and a few retaining walls. My neighbor came and helped with the pour. I finished the block work the following day
Rebar for all of the rock work. I am not a fan of hollow rocks, everything will be filled with broken concrete and shot over or solid shotcrete. I am guessing it will be around 100 yards. I am planning on two pumps running all day.
My wife says it looks like an airplane crashed in the backyard!
Wow!
Nice work man! If you dont mind me asking, how long has it taken you to get to this point?
I finished the plans in July and started digging in august. I think the shotcrete went in at the end of October. I'm not in a huge hurry since summer is so far away and I'm busy juggling other projects. I have a different full time job so this pool is a side gig to my side gig. I have more pictures coming....
That is awesome!! So unique! I don't think I've seen anything else quite like it on here! How deep does it go?
Its 6 feet at the deepest. I'm not a fan of super deep pools since that area is only good for diving. I'm not going to hang out there and tread water for hours on end. I also wanted to keep the gallonage as low as possible since the pool is so big.
I started framing the pool equipment shed. This shed has turned into an absolute nightmare with the county building department...they don't know how to classify it :hammer:
I also framed the pergola and fireplace. I'm using a natural gas insert. I was originally going to build a wood burning masonry fireplace but opted for gas for simplicity. If you want a fire, you want it now, and when you're done, you're done. The pergola is all resawn doug fir. The curves were my wife's request...I hope I never have to cut those again. They were also quite heavy:sad:
Plaster for the rock work has begun. My wife and I both like mostly grey and this is how most will look.
