Page 1 of 10 1234 ... LastLast
Results 1 to 20 of 199
Thread: SoCal Rock Pool
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,742
    SoCal Rock Pool
    I have enjoyed looking at everyones pools, so I figured I should take the time to post mine. Here is the basic design I came up with...I am fortunate to be able to do my own plans and a majority of the work. I plan to do as much as possible myself.
    -Brian-
    33K Pool/Spa, Pentair Equipment
    POOL BUILD
    Davis Custom Construction - Home Page
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,742
    Re: SoCal Rock Pool
    -Brian-
    POOL BUILD
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,742
    Re: SoCal Rock Pool
    Plumbing going in. I went with 3" lines in a looped return system for the pool. I thought long and hard about the infloor system but chose not to based on mixed reviews. I'm hoping I don't regret it.
    -Brian-
    POOL BUILD
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,742
    Re: SoCal Rock Pool
    Rebar going in...got a hand from my little helper
    -Brian-
    POOL BUILD
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,742
    Re: SoCal Rock Pool
    Dug the footings for the fireplace and a few retaining walls. My neighbor came and helped with the pour. I finished the block work the following day
    -Brian-
    POOL BUILD
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,742
    Re: SoCal Rock Pool
    Rebar for all of the rock work. I am not a fan of hollow rocks, everything will be filled with broken concrete and shot over or solid shotcrete. I am guessing it will be around 100 yards. I am planning on two pumps running all day.
    My wife says it looks like an airplane crashed in the backyard!
    -Brian-
    POOL BUILD
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,742
    Re: SoCal Rock Pool
    Ended up being 112 yards. We finished up right about the time the sun set
    -Brian-
    POOL BUILD
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,742
    Re: SoCal Rock Pool
    -Brian-
    POOL BUILD
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Re: SoCal Rock Pool
    Wow!
    Nice work man! If you dont mind me asking, how long has it taken you to get to this point?
    Divin Dave,
    PoolESQ's Avatar
    Dec 2007
    Albuquerque, NM
    191
    Re: SoCal Rock Pool
    That is awesome!! So unique! I don't think I've seen anything else quite like it on here! How deep does it go?
    Replastered 2015: Sunstone Quartz Midnight Blue 16x32 rectangular gunite with in-pool spa....18,000 gallons. Autopilot Total Control System with SWG and acid pump. Pentair Clean & Clear 420. Auto cover. TF-100.
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,742
    Re: SoCal Rock Pool
    Quote Originally Posted by Divin Dave View Post
    Wow!
    I finished the plans in July and started digging in august. I think the shotcrete went in at the end of October. I'm not in a huge hurry since summer is so far away and I'm busy juggling other projects. I have a different full time job so this pool is a side gig to my side gig. I have more pictures coming....
    Quote Originally Posted by PoolESQ View Post
    Its 6 feet at the deepest. I'm not a fan of super deep pools since that area is only good for diving. I'm not going to hang out there and tread water for hours on end. I also wanted to keep the gallonage as low as possible since the pool is so big.
    -Brian-
    POOL BUILD
    30,416
    Re: SoCal Rock Pool
    That's an awesome DIY undertaking. Very, very nice work!
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,742
    Re: SoCal Rock Pool
    I started framing the pool equipment shed. This shed has turned into an absolute nightmare with the county building department...they don't know how to classify it
    I also framed the pergola and fireplace. I'm using a natural gas insert. I was originally going to build a wood burning masonry fireplace but opted for gas for simplicity. If you want a fire, you want it now, and when you're done, you're done. The pergola is all resawn doug fir. The curves were my wife's request...I hope I never have to cut those again. They were also quite heavy
    Plaster for the rock work has begun. My wife and I both like mostly grey and this is how most will look.
    -Brian-
    POOL BUILD
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,742
    Re: SoCal Rock Pool
    -Brian-
    POOL BUILD
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,742
    Re: SoCal Rock Pool
    Scratch coat on the fireplace. It will get veneer stone to match our house. I framed the mantle and stuccoed it to match the pool's rock work.
    -Brian-
    POOL BUILD
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    SoCal Rock Pool
    You guys have some awesome taste. This is one heck of a DIY pool.
    Jeff
    Re: SoCal Rock Pool
    Outstanding! Keep the updates coming.
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,742
    Re: SoCal Rock Pool
    Quote Originally Posted by pwrstrk View Post
    Thank you both!
    -Brian-
    POOL BUILD
    TulsaKevin's Avatar
    Dec 2014
    Tulsa OK
    66
    Re: SoCal Rock Pool
    I don't know what your "real" job is but you need to quit and become a pool builder, looks great. The plaster on the rock looks fantastic. What are the dimensions of the pool.
  20. Back To Top    #20
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,742
    Re: SoCal Rock Pool
    Thanks for the compliment.
    The pool is 56 x 32 with an 8' spa. The reef area is 24x20. Its is 1250 sq ft including the spa, 180' perimeter.
    -Brian-
    POOL BUILD
