Results 1 to 9 of 9
Thread: Lights!
    Shirker's Avatar
    Jul 2014
    Athens, GA - USA
    132
    Lights!
    Any recommendations on lighting an above ground pool on the cheap? I like the idea of the little floating solar rechargeable LED lights but worry they will not be bright enough for me. Would I be better off just biting the bullet and installing a real pool light? 20 foot diameter round with steel walls.
    P.s. this pool has ruined me. I used to love fall and winter. Now all I can think about is opening up for season two (first full season).
    TF-100 | 13.6k gal (24' Round) AG | Chlorine | Sand Filter | Two Speed Motor | Installed June 2014 | Last Opened April 24 2016
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: Lights!
    Here is the light I use. It has worked great and will be on its 3rd season. This is just an example as you can find the light at numerous places online. Just google nitelighter.
    https://www.yourpoolhq.com/nitelight...FdgBgQod3yYAqQ.
    Jeff
    Glock's Avatar
    Jun 2012
    Mesquite, Texas
    866
    Re: Lights!
    I have the nitelighter 100 too. its good a bright but it keeps filling with water. not sure why. I wish someone would make a real light for above ground pools.
    18x34 Doughboy AGP 22300K Gallons - Build Thread
    Aquaview 24" Sand Filter - 1.5 HP Powerline Pump - Barracuda Ranger - Taylor K-2006 - BBB
    Pool School and Pool Calculator
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: Lights!
    Haven't had that problem with mine.
    Jeff
    Shirker's Avatar
    Jul 2014
    Athens, GA - USA
    132
    Re: Lights!
    Filling with water seems to be one of the main complaints I have read about on Amazon (50 watt and 100 watt). That and the bulb not lasting very long. I think I will give the nitelighter a try though. How do you turn it on/Off? I can just plug it into a standard 15 amp receptacle, right?
    Glock's Avatar
    Jun 2012
    Mesquite, Texas
    866
    Re: Lights!
    Yes, the power converter has a push button/GFI switch built into it. Its a good light, it just needs to be sealed better. I actually thought about getting a 2nd one since one end of my pool is not very well lit but its not like its dark on that end. We don't get out there in the dark very often either. I need to remove it and rebuild it. It's 12 volt too. I guess I could convert it to LED and then seal the light component in an epoxy to alleviate any water issue. An LED version would be really cool, especially if you could change the color on the fly.
    Orlando, FL
    690
    Re: Lights!
    I have the Nightliter and the only time it got water in it was when the cover was not seated correctly. I just keep redoing the cover and finally got it. I have the multicolor and the kids love being able to pick their favorite color. I found a great deal on Ebay.
    Sharkline Reprieve 15x52 (3/14). Still using Intex 2650 Sand Filter with Hayward Power-Flo Matrix 3/4 HP pump (6/15). Solar Cover cut into strips for easy removal, (2) 2*10 Space Saver solar panels. Swim Jet HD Robot (by Aquabot) (3/15). Chlorine Liquidator (4 gal). 4 person hot tub. Hard pipe is the way to go for improved flow! Retired Lil Shark (3/15). Starite Max E Therm 333k BTU Propane Heater w/ 24 gal tank (7/15).
    Shirker's Avatar
    Jul 2014
    Athens, GA - USA
    132
    Re: Lights!
    Thanks for the feedback guys, I have already put the Niteligher 100 in my Amazon wishlist. I will prob wait until after I open to buy it though. One more question, do the colored lenses just snap on over the primary cover or do you have to take it out of the water to change the color?
    Orlando, FL
    690
    Re: Lights!
    Colors change by pressing the mode/mood selector switch. You can select one of the three colors or have it rotate through all of the colors. Once it is in the pool, you only need to remove it when a bulb burns out.
    You may already know this but I believe....there is a Niteliter 100 and a Niteliter 100 MC (multi-color). Double check to make sure you have selected the one you really want.
