Results 1 to 7 of 7
Thread: programming EasyTouch Led lights
    Dec 2014
    Houston, TX
    9
    We have one circuit for pool lights and another circuit for water feature lights. I have been trying to set the pool lights to Blue and the water feature lights to Red. I went into the EasyTouch programming and in the lights menu went to configure and for each circuit I set the color that I wanted. However, its not working. When the automatic schedule turns the lights on they go to the last color that they were on. If I had Sunset mode on then all the lights come on using Sunset mode.
    How can you program the EasyTouch system to turn on the lights using the schedule but use the configured colors? Thanks.
    Dec 2015 fill date IG plaster pool, 8000 gals. Pentair cartridge filter, Pentair filter 1 Hp pump, Pentair Legend cleaner, Pentair Easy Touch Control Center, and TF-100 test kit
    Re: programming EasyTouch Led lights
    What model of light do you have? And is the EasyTouch setup to know that you have that kind of light?
    Dec 2014
    Houston, TX
    9
    They are the intellibrite led lights. I checked to make sure that the setup had that selected and it was selected.
    The setup sequence for IntelliBrite lights has a couple of different sets. First make sure the aux circuit that controls the lights is given a name. Then in the Circuit Func. menu make sure that circuit is assigned as an IntelliBrite. Then from the Lights menu try the sync function and see if it will work after that.
    dumbcluck's Avatar
    Aug 2013
    long beach
    674
    I think if you want a certain color you click on the color lights button instead of the intellibrite one and then choose light colors for each circuit.
    I'm still trying to figure this one out myself.
    -Jimbo- My pool was full of dirt and trees. Now it's full of water and children!
    20k gallon inground pool, 18" raised spa 7' round, 8 jets, 3" spa plumbing. Pentair intelliflo 3hp vsp, Easy touch 4 w/ ic 40, CCP 420 cartridge filter, Raypak 407a w/ cupro nickel, Screen logic 2, Pentair intelliph, spa side remote, Pentair 5g color lights pool and spa, TF-100 test kit with speed stir and Dolphin Oasis Z5
    Dec 2014
    Houston, TX
    9
    so i made sure the circuits were named and assigned to Intellibrite. I did a reset and also did a manual ALL OFF for the lights. Then I configured the colors I wanted under the lights configure menu and it seemed to have worked. Thanks.
    MARCO...polo's Avatar
    Oct 2014
    East Contra Costa County CA
    102
    I have issues with this as well. I gave up and just use the ON/OFF method to get the colors/show I want. I will try the above suggestions though.
    13,000 gal.Peanut shaped IG Plaster (med. gray) w/ 7' raised spa. ALL Pentair: Intelliflow 3hp VS, Cartridge filter, 400,000 btu heater, 2.0hp spa motor, Easy Touch control panel & is4 spa side switch, Intellichlor 40C SWG, Paramount PV3 In Floor cleaning system, spa spillway and two sheer descents. Solar: 10 FAFCO panels 1.5hp booster. Testt kits: K-2006 & K1766 (Chloride/Salt) Fill date August 15, 2114.
